Old 02-22-2007, 12:22 PM   #1 (permalink)
audiophile's Avatar
Ben
Skunk2 Camber arms *squeak squeak*??
Installed my camber arms yesterday. No problems at all........except.
THEY SQUEAK!!
Did i do something wrong? I don't think I could have...the installation was very straight forward. My wheels look correct and identical on both sides. I wanted to know before I got an alignment tomorrow morning.
If they are going to continue to squeak I'll just take the mothers off (its that bad) and get an alignment w/o them. then sell them.
I'd really rather get 10k less on my tires and buy new ones than have this squeak every day.
audiophile is offline   Reply With Quote
Old 02-22-2007, 12:33 PM   #2 (permalink)
06blaksi's Avatar
hmmmmmm...I installed mine on Sunday and no problems here. Are all the mounting bolts torqued correctly?
Old 02-22-2007, 01:14 PM   #3 (permalink)
audiophile's Avatar
Ben
I do not have a torque wrench... but I am very mechanically inclined. Could I have over-tightened the outer 14mm bolt? That was my first impression but I wasn't sure...
Old 02-22-2007, 08:59 PM   #4 (permalink)
Mine squeaked when I first installed them....try loosening off the bolts and re-tighten them with the car on the ground.
worked for me
Rallyfocus is offline   Reply With Quote
Old 02-22-2007, 11:33 PM   #5 (permalink)
Moderator
sickyute's Avatar
Marvie
worked for me
yes .. do that ..
plus make sure u are using the correct moutning locations depending on how much -/+ camber u want ... if the camber kit is close to it's limits it will squeak .. i had that problem as well ...
Shift when it blinks!
Old 03-05-2007, 02:05 PM   #6 (permalink)
06blaksi's Avatar
Grrrrrrrr
2 weeks later and today they start squeaking at low low speeds over decent sized bumbs and speedbumps....I'll try tightening them when I get home from work.......Did this fix your problem?
Old 03-06-2007, 08:45 PM   #7 (permalink)
Grease..Grease..Grease. This is a huge factor in squeaking. I greased every moving part in the back finally no more annoying squeak. I have yet to install any suspension products just stock si sedan. Had a squeak in right rear. Gone now used a common lithium based grease. Honda skimps here and there. lol. No but really some cars get more than others in the assembly process. It is fixable, squeaks can't hide.
Skin441 is offline   Reply With Quote
Old 03-06-2007, 11:39 PM   #8 (permalink)
faptasic... pew pew pew
rippars's Avatar
Ryan
havent had any problems with mine yet and it been about to two weeks... like the above user said, i did grease the bushings a bit just in case.
< click and donate nao
Originally Posted by jasonandre
Who wants to wash my car?
Originally Posted by dentrecords
sure. where would i find it?
Old 03-07-2007, 02:07 PM   #9 (permalink)
audiophile's Avatar
Ben
I noticed no grease whatsoever when I removed my factory stuff, so the thought of adding grease never crossed my mind.
I've got a rattle-can of white lithium grease I used on the window motor gears in my old truck... would this work? Or something not out of an aerosol can?
It's supposedly "water and element proof"
edit: 06blak - i tried that and still... squeak squeak..
Old 03-07-2007, 02:15 PM   #10 (permalink)
06blaksi's Avatar
yea...I'm still squeakin too........it's embarrassing when people are in the car...I get stuff like I thought this was a new car, it shouldn't do that......
Old 03-07-2007, 02:33 PM   #11 (permalink)
Ever try adding bearing grease to the fittings?
blueroadster is offline   Reply With Quote
Old 03-07-2007, 07:30 PM   #12 (permalink)
It is there somewhere. What if it is a little dwarf in their doing it to piss you off. but really try to grease anything and everything aerosol lube probally will dry out. But yah that grease you used for the windows will work. Don't need much. Just a dab.
Old 03-07-2007, 11:56 PM   #13 (permalink)
audiophile's Avatar
Ben
I have not but that sounds like an excellent solution... I'll keep errbody updated. I'll do it tomorrow after work (5ish central)...
Oh yeah, I got my HID's in the mail today. I might try to do those tomorrow too
If I finish I'll post pics.
Old 03-08-2007, 12:11 AM   #14 (permalink)
Seemund's Avatar
yes, me too.. First I was thinking: maybe its something in the trunk..
but my trunk is empty and I'm still getting a squeak from the back right side
I just lowered with Tein S-techs + skunk2 arms
Seemund is offline   Reply With Quote
Old 03-08-2007, 02:28 AM   #15 (permalink)
Corey
Man, I hope mine won't squeak when I put mine on. That would be embarrasing. If the grease works, I'll probably put some on before squeaking can even have a chance to occur.
06_fiji_si_85 is offline   Reply With Quote
Old 03-08-2007, 10:25 AM   #16 (permalink)
Bartman619's Avatar
I remember in my '95 Integra, after i put in some new adjustable cambers it started to squeak bad. I took some tips from the old Hond-Tech forums. Get yourself some synthetic or silicone based spray lubricant and spray the rubber bushings on the camber arms real well. Let it soak in and wipe off the excess....my two cents.
Bartman619 is offline   Reply With Quote
Old 04-02-2007, 10:10 PM   #17 (permalink)
Seemund's Avatar
could anybody please take a pic of the place that has to be re-tighten?
I paid a friend to do the install, and now I'm getting extremely loud noises..
clunk clunk
looks like my car is from 1959 I already try to spray some WD-40 at the camber arm.. but nothing still nothing!
The sound comes from the back of the car.
Old 04-02-2007, 10:12 PM   #18 (permalink)
06blaksi's Avatar
clunk clunk
I didn't re-tighten. I went and got the white lithium grease in a spray can like Skin441 suggested and the creaking went away. I still have clicking from my Teins in the front tho
Old 04-02-2007, 10:19 PM   #19 (permalink)
Seemund's Avatar
I don't have a problem with my S-tein, the problem is with the camber arms..
The sound comes from the back, and its really LOUD.. REALLY.. even with windows closed
Old 04-02-2007, 10:26 PM   #20 (permalink)
wrong thread, how do i delete this post?
Shinobi is offline   Reply With Quote
Brand New Part: Skunk2 Rear Camber Arms: SPECIAL PRICING CorSport CorSport 137 04-22-2008 07:05 PM
Installing Camber Arms - How Much Time Should I Pay Rpm2 Suspension and Brakes 11 03-04-2007 02:53 PM
SPC Camber Arms w/S-Techs 07 Si Sedan tonydrone Suspension and Brakes 15 01-12-2007 01:23 PM
