LinkBack (2) | Thread Tools | Display Modes |
#23 (permalink) |
8thcivic Sponsor
Sweeeeeeet! Nice pice and info. Thanks man!
For those of you who still need a set: Brand New Part: Skunk2 Rear Camber Arms: SPECIAL PRICING ^click it Tai |
#24 (permalink) | |
#27 (permalink) | |
#28 (permalink)
Here is the DIY information for installing the rear camber arms...I'd also like to thank mishima8 for the help. Here we go.
First jack the car and support with stands (you could also do one side at a time if you want, but my car was already on stands at all four corners anyway). Second, remove the rear tires. At this point, use your jack and place it under the rear lower control arm knuckle. Raise the jack up until the weight of the suspension is fully supported. Here is a PIC: ![]() Remove the two 14mm bolts on the upper camber arm assembly. ![]() Next, remove the one 14mm bolt on the upper camber arm where it connects near the brake disk. ![]() Here is a PIC of all three bolts removed: ![]() Remove the stock upper camber arm, and thread a socket extension through one end and then also attach the Skunk2 camber arm assembly. Doing this will allow you to adjust the Skunk2 camber arm so that it is adjusted to the exact same length as the stock one. ![]() Here is a PIC of the other end showing the connection points being the same: ![]() Once set, you are ready to install the Skunk2 camber arm assembly. First install and tighten until snug the 14mm bolt in the below PIC. ![]() Next, push on the top of the brake disk assembly until the holes for the other connection point are lined up and then install and tighten until snug, the other 14mm bolts in the below PIC. ![]() Once you are done with that, do the other side using the same process. Put the wheels back on, lower the car (this is important to make sure that the suspension is loaded before tightening) and then torque the three bolts on both sides as follows: One 14mm bolt next to the disk brake: Tighten to 79 foot pounds Two other 14mm bolts: Torque to 43 foot pounds |
#34 (permalink) | |
#37 (permalink) | |
Had a great time as well...Thanks for all of the help. Looking forward to the next meet where we can keep on modding. |
#39 (permalink) | |
Left (Driver's Side): 1.787 kilograms or 3 pounds 14 7/8 ounces Right (Passenger's Side): 1.707 kilograms or 3 pounds 12 ounces The right side weighs a little more as there is an additional bracket welded to the part to identify that it is suppose to go on the right side of the car. As a result, the weight saved by replacing the stock arms with the Skunk2 version is as follows: Left (Driver's Side): 365 grams or 12.8 ounces Right (Passenger's Side): 445 grams or 15.7 ounces The stock arms are made of steel with a hollow core whereas the Skunk2 ones are solid machined aluminum. The Skunk2 is also better as it allows for the camber to be adjusted (this cannot be done with the stock arms as there are no adjustment points). Last edited by blueroadster; 02-18-2007 at 01:00 PM. |
#40 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/29219-skunk2-rear-camber-arms-assembly-part-details-pic-heavy.html
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | Post #0 | Refback | 02-27-2008 07:56 AM | |
| DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum | Post #0 | Refback | 01-19-2008 11:46 PM | |
