Old 02-14-2007, 04:25 PM   #1 (permalink)
Si4Life's Avatar
Whos High Pitch?
springs for an 07 Si Sedan?
anyone know of springs for a 07 si sedan?
Si4Life is offline   Reply With Quote
Old 02-14-2007, 06:49 PM   #2 (permalink)
you can use the si coupe springs
StLVtec is offline   Reply With Quote
Old 02-14-2007, 10:18 PM   #3 (permalink)
SiCali's Avatar
i wouldn't recommend doing that since the weight distribution b/w the coupe and the sedan are different. yes, they would probably work, but you're increasing your risk for suspension issues. there are several aftermarket springs out there. just look for them specifically for the si sedan.
SiCali is offline   Reply With Quote
Old 02-14-2007, 11:29 PM   #4 (permalink)
Si4Life's Avatar
Whos High Pitch?
aiight....thanks
Old 02-14-2007, 11:53 PM   #5 (permalink)
fyreant's Avatar
ANT
the honda factory performance springs/strut set will be available in spring.. if your in it for the performance then wait for those.. if you just want to lower it for looks then you can find some good aftermarket kits on the net..
fyreant is offline   Reply With Quote
Old 02-15-2007, 12:27 PM   #6 (permalink)
Si4Life's Avatar
Whos High Pitch?
I just looked on the eibach site and the sportline part number is the same for both coupe and sedan.
Old 02-15-2007, 12:46 PM   #7 (permalink)
fyreant's Avatar
ANT
that may be due to the way they make thier springs.. that not applicable to HFP..
Old 02-15-2007, 02:40 PM   #8 (permalink)
DakRaven's Avatar
According to Honda the springs rates are the same between the Coupe and Sedan Si. If you are just changing the springs (i.e., Eibach Pro or Sportlines), then no problem with the Coupe coils. However, the Struts/Dampners will be different due to weight bias and even though they will fit from the Coupe to the Sedan, they may not perform as well as a set made for the Sedan.
Hope that clears it up.
DakRaven is offline   Reply With Quote
Old 02-15-2007, 07:13 PM   #9 (permalink)
thats what i was told that they both are the same for coupe and sedan si
Old 02-15-2007, 09:02 PM   #10 (permalink)
mishima8's Avatar
Or you can check out Mugen's kit. I posted it here a week ago or so.
mishima8 is offline   Reply With Quote
Civic SI Sedan Comes To America - Chicago Auto Show Debut webby Honda Industry News 11 04-19-2008 10:24 PM
pic of NEUSPEED RACE springs (sedan) on 17s 2006exsedan Suspension and Brakes 29 01-12-2008 06:53 PM
TEST DRIVE: Si Sedan (Nighthawk Black Pearl) - No Pics CameronJr9 Driving Experience 33 11-28-2006 11:35 PM
TOV: Si Sedan first drive skittleslegend Civic SI 38 09-24-2006 12:46 AM
Which Springs for EX Sedan Gaspar_06_Civic_EX Suspension and Brakes 23 07-15-2006 04:19 PM
