noise from rear neuspeed race spring
i got a sedan and i installed my neuspeed race spring a week ago, and after a while i realize there is a noise coming from the rear everytime i hit a moderate bump.. i looked down and find out that the springs is actually touching each other at the top.. so most likely the noise is coming from the springs touching when i hit a bump
is it normal for the top part of neuspeed race to touch each other like this?? ![]()
I have Eibach's so I can't say about the Neuspeed. But, my best guess is you need to lube the rubber spring seats where the spring meets them. Just jack up the rear and let the suspension go to full drop, then spray the seat area real good with some white lithium grease. Your nosie will most likely go away. Mine made noise too & this fixed it.
If you want to go to extremes, pull the springs back out & wrap the ends with teflon tape. |
| noise from rear... hfp suspension and progress rear sway bar | rippars | Mechanical Problems & Technical Chat | 8 | 07-01-2008 09:42 PM |
| s tech tein spring, need a rear camber kit? | ronjancivicsi | Suspension and Brakes | 4 | 04-06-2007 11:25 PM |
| Megan H-Brace and lower rear brace Review | 604_ep3 | Suspension and Brakes | 38 | 03-21-2007 02:32 AM |
| Neuspeed Race Spring Done (06 civic si) | 06_civic_si_gi | Suspension and Brakes | 17 | 06-28-2006 04:20 PM |
| Rear Disk Brakes Noise | ONEtdiddy | Mechanical Problems & Technical Chat | 9 | 06-02-2006 01:43 PM |
