anyone else get this woo woo woo sound when breaking?
before I come to a complete stop when im at a fairly slow speed and have the radio off I hear a woob ,woob, woob, woob sound as I come to a stop from the breaking...is this normal I have falken tires in stock size but I dont think that would do it.....Its probably alwasy done it I just havent noticed
#2 (permalink) | |
Have you been drving at a high rate of speed and use your brakes fairly hard? Your rotors may be warped... Also having your lug nuts on each wheel not all tightened to factory specs the rotor will heat up the hub assembly, which in turn heats/warps the rotors during the same braking. If they are warped a decent automotive shop should be able to turn your rotors and re-surface them. |
hmmm idk it does it even not on the brakes like coasting slow through a parking lot you hear it a bit...i torqued the lugs all to spec when I swapped rims...noshaking at all when stoping either...maybe a slight warpage...still smooth though...time to upgrade rotors hehe
![]() Join Date: May 2006
J. M. back by popular demand!
![]() Visit my city! Free vagin for every resident (in direct contrast to the other cities that only provide free Fleshlites!) http://eat-mykhram.myminicity.com/ |
#8 (permalink) | |
#18 (permalink) |
bubb rubb : chillin at the mansion - http://www.youtube.com/watch?v=USd3O...elated&search=
"and i didnt see the mothaf*ckin hole in the ground.. thats where i took flight." ahahahah and yes.. hes high |
#19 (permalink) |
I hate you
My g35 made the same noise, but it was due to the tires. It only does it under braking? Or even if you're coasting at slow speeds?
![]() "8thcivic.com where everyone holds hands, nutswings and paints everything in time attack fashion" -Michael Bolton |
| popping sound from right front(passenger side) | sickyute | Suspension and Brakes | 14 | 11-24-2007 07:19 AM |
