Old 02-10-2007, 12:03 PM   #1 (permalink)
SiLvErLIgHT06's Avatar
Will the dealership know
that i had my HFP suspension done by a private party?? Or can i just lie to them and tell them that it came like that from the factory. I ask this because i just got an alignment done and i have -2.30 degrees of camber on my rear right wheel. I took a look at the wheel and it's sitting like this: \, obviously not as bad. My left rear wheel has -1.76 and it looks good. Anyway i can fix this? I don't remember hitting any potholes or anything. I want them to fix it but i don't want them to blame it on the suspension. Any help is appreciated, thanks.
SiLvErLIgHT06 is offline
Old 02-10-2007, 12:10 PM   #2 (permalink)
DATA02's Avatar
Most dealerships will have all recorded documentation of work done on a vechile... Sometimes even if you know nothing about it! Problem is, if you try and pull your [warrenty] card, chances are they will probably pull your [BS] card. Good luck
DATA02 is offline
Old 02-10-2007, 12:18 PM   #3 (permalink)
Rems07si's Avatar
Remy
yes they will
Rems07si is offline
Old 02-10-2007, 12:19 PM   #4 (permalink)
Well then how about my camber?? Should i worry about it?? Or just leave it, the guy said it shouldn't be a huge problem, what do you guys say?
Old 02-10-2007, 12:47 PM   #5 (permalink)
you don't know me
Toys For TotsMember
06blaksi's Avatar
You're going to have camber with any suspension on this car even stock. It's fine. I believe you can go up to -3 degrees and still be good
06blaksi is offline
Old 02-10-2007, 12:54 PM   #6 (permalink)
But shouldn't both rear wheels have around the same camber? Not just the right one?? Or should i just get a camber kit?? Will that help??
people were crazy at the dealership today! rippars Garage 13 05-28-2007 12:01 PM
Jihad Car Dealership? Special Ringpop Garage 11 09-26-2006 06:57 PM
