![]() ...anyone here using this fluid? i hear its great for performance driving. from upr.com: Extreme thermal resistance and stability. The elevated boiling point of RBF 600 FACTORY LINE (312°c / 594°F) enables effective braking even under the extreme conditions of competition. I plan to use this once i install the Stainless steel break lines, and Hawk HPS *plus* pads. Sorry to say, but the Si's OEM Break system blows! The breaks feel very mushy..since day 1. |
Moderator
me ... but u already know that
i like it ...
#3 (permalink) | |
![]() here's some info on the DOT 5.1 brake fluid: Non-silicone based, long life and 100% synthetic, DOT 5.1 BRAKE FLUID conforms to the highest standards in brake fluid performance. DOT 5.1 is specially designed for Anti-Locking Brake Systems (ABS). With a high dry boiling point of 270°C and a high wet boiling point of 185°C, DOT 5.1 delivers the best brake performance. |
Moderator
check ur owners manual ... it doesn't recommend going above DOT 4.
Moderator
haven't done it so i don't know.
Go with both the Motul RBF600 and the ATE Super blue.
Alternate between fluid changes, the different colors help you tell when the flush is completed.. Both are great high temp fluids. I'm using the super blue first so I can tell when all of the factory fluid is flushed, then on the next change I'm using the RBF 600. I've used the Motul RBF 600 for years for downhill mountain biking to help prevent vapor lock / fluid boiling at altitude.. |
| So the Girlfriend says she wants a break... | SIpimpin13 | Water Cooler | 58 | 11-02-2008 01:59 AM |
| ate super blue brake fluid | eugenekim.net | Suspension and Brakes | 14 | 04-28-2007 05:15 PM |
| changing oil after break in | IWANNAGOFAST | Mechanical Problems & Technical Chat | 6 | 01-02-2007 11:26 AM |
| First oil change/trans fluid change BEFORE 3500 miles? | djdefcon | Civic SI | 7 | 08-22-2006 09:36 AM |
| Got an aftermarket stereo? How many watts are you running? | JamesC | I.C.E., Electrical, Security, & Navigation | 3 | 05-30-2006 05:08 AM |
