Old 01-29-2007, 12:25 PM   #1 (permalink)
What could cause caster to be so far off other than an accident???
Front passenger side caster is supposed to be 7.0.
Immediately after lowering the caster is now 3.5 and there is no caster adjustment. Every-1 I speak too about this are baffled that the caster is this far out of spec.
Given that when you adjust your subframe you are only going to gain +or- .5.
thanks
mc1200s is offline   Reply With Quote
Old 01-29-2007, 09:11 PM   #2 (permalink)
Im an idiot---I mean caster, not toe
Old 01-29-2007, 10:04 PM   #3 (permalink)
jcxcr4000's Avatar
joel
either way something is bent either the strut or control arm
jcxcr4000 is offline   Reply With Quote
Old 01-30-2007, 02:54 PM   #4 (permalink)
honda93's Avatar
Something is either bent or bound.
OR
Did you make sure the upper bearing plate (or spring hat) was installed correctly (where the strut assembly actually bolts to the unibody)? There's a certain way in which it is supposed to face.
Anthony "Mario" Crea
NNJR-SCCA
Guy just witnessed a car accident... CameronJr9 Water Cooler 1 10-11-2006 11:30 AM
I lost my accident virginity 6spdChick Water Cooler 35 08-29-2006 09:49 AM
