Old 01-26-2007, 10:25 PM   #1 (permalink)
K20FG2's Avatar
Camber Kit with HFP suspension?
Hey guys, I'ver been thinking about getting the hfp suspension package for my Si, but I don't know if I should get front and rear camber kits as well? On one hand, the geometry of the suspension is changing with the different suspension, so you would think a camber kit would be needed to get that straightened out. On the other hand, what if you bought your car off the lot with the hfp package on it, and as far as I know the dealer doesn't use camber kits---wihich also doesn't doesn't make sense because it doesn't seem like a dealer would sell you a brand new car with improper camber. So anyways, I'm kinda confused about the whole thing, let me know what you think. Thanks.
K20FG2 is offline
Old 01-26-2007, 10:34 PM   #2 (permalink)
I believe from what I have been hearing, the HFP kit doesn't need a camber kit. It's designed to work without the use of those. The drop is extremely mild (.8 inches) ..but I've been hearing from several members from this board that it handles like a dream. So, don't like the height fool ya!
taffysi is offline
Old 04-27-2007, 02:10 AM   #3 (permalink)
Kelly.J's Avatar
Justin
as taffysi said, it is just .8 inch..
within 1 inch,(some says up to 1.5 inches) u don't need to worry about camber kit..
but I just remember that the guys from honda had hard time to get alignment of my car.. when i installed HFP..
if your tires are worn out evenly.. it's ok
but if they are not, got to get the camber kit.
according to this, .8 inch doesn't matter.
if u wanna make it(tires are gonna stick to the ground evenly) sure,
get a camber kit..
Kelly.J is offline
Old 04-27-2007, 02:15 AM   #4 (permalink)
SiRyan's Avatar
no need, i didn't need them.
SiRyan is offline
Old 04-27-2007, 02:15 AM   #5 (permalink)
the front is definately not needed.. as for the rear.. youll be fine.. its just an inch.. usually anything that surpasses an inch drop camber kits are needed maybe theyll be little very little camber.. but thats how honda comes out right off the lots.. for handling purposes so little camber is good! good luck and have fun with the set up!!
Steviephamo is offline
Old 04-27-2007, 02:16 AM   #6 (permalink)
Jardiniboy's Avatar
Jasten
Personally it's up to you if you want the camber kits. I mean you don't have to but it's good you have one because with the HFP suspension, your alignment if not gonna but out of specs but you will have a little more camber and tire wear in the inside of the tire. With the camber kit you could put it back to stock settings and have even tire wear. Plus it's good to have one if you plan to change to coilovers in the future. I say get it. But you don't have to if you don't want to.
Jardiniboy is offline
What I learned about the HFP Aero Kit!!!!!! cornerstrike Inside and Out 26 03-22-2007 10:07 AM
HFP Suspension Kit...auto vs manual??? DooD Suspension and Brakes 4 12-13-2006 08:32 PM
HELP!!! Camber problem with Si suspension on LX aircuellar Suspension and Brakes 10 09-25-2006 09:41 AM
What I learned about the HFP Aero Kit!!!!!! cornerstrike Inside and Out 9 09-05-2006 03:03 PM
