Nasty popping from the front right on my lowered Si? - Page 2 - 8th Generation Honda Civic Forum
Closed Thread
Old 06-27-2007, 04:21 AM   #21 (permalink)
Well i bought a coupe 07 automatic tranny and i haev the same problem
im going to get it checked on when i get my first oil change
but its also on the right side and i couldnt figure out what it could be
rocfella05 is offline
Old 06-27-2007, 04:25 AM   #22 (permalink)
Civicsalesman's Avatar
Not trying to hi - jack your thread here. Think of it as a free bump........... anyways as far as the stock set up knocking over speed bumps, what is the remedy to fixing that? thanks
Civicsalesman is offline
Old 06-27-2007, 04:35 AM   #23 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
"Stance"...The new jockstrap
Originally Posted by JDoc
Sup guys, just to let you know i do beleive its the s-techs. I got them in not too long ago and the noise started ever since they were put in. I just got used to it, for me it only happens when i have to park and turn my wheel far to the left or to the right.
Same deal. Never happened until I put the Skunk 2 springs on, and it only happens occationally when I'm driving slow in a parking lot, or turning into a parking space.
mattsbobo is offline
Old 06-27-2007, 06:54 AM   #24 (permalink)
PeterC.'s Avatar
That's my real name!
Guys, if it is happening to stock cars then it is not a problem directly attributable to the after market springs. The springs brought out the problem but it didn't cause it. The best thing to do would be a trip to your dealer. They shouldn't say anything about your springs considering this is happening to unaltered Civics as well.
PeterC. is offline
Old 06-27-2007, 10:31 AM   #25 (permalink)
sickyute's Avatar
Marvie
i just found out something ...
1st it was engine rocking
2nd it was a loose steering bolt under the car
and now i've realized the stock aero pannel at the back of the car rattles against something back there ... i took it off after i couldn't find the cause of a popping noise when i thought it was my sway bar or spring not seated right in the rear ...
what i noticed is that honda placed a piece of foam back there, on the pannel itself, to the side of it to prevent noie from lateral movement, but the foam started to wear away/ squish etc. and doesn't do it's job like before ... and with the stiffer ride it's easier to get that stuff to shake around and so the noise ...
i added another peice of sticky foam tape and the noise is gone from lateral movement ... but it was still there from vertical movement so i added a piece to the top of it then bolted it back down and now peace and quiet
easy fix.
it was clear to see that it was the culprit of the noise after i took it off ... i could see the wear marks on the plastic and on the metal is was hitting ...
may not be the same for you guys but it's worth a check if u have noise coming from the rear...
mine used to happen when i was just pulling out of my spot and hit a manhole or uneven road or something but usually when i was going slow...
and yeah the noise sounds like it's coming from the right rear ... and the right rear is the only place that has that foam ...
see on the left side of the pannel it's bolted down so it doesn't shake ...
left side .... bolt to top and side ...
right side ... bolt to top and a small piece of foam tape on the side
Shift when it blinks!
sickyute is offline
Old 06-27-2007, 11:53 AM   #26 (permalink)
JRM_FG2's Avatar
Jason
easy fix.
im getting a noise from the rear of my car also, gonna have to check if this is the problem.
JRM_FG2 is offline
Old 06-27-2007, 11:11 PM   #27 (permalink)
0oE
0oE's Avatar
WTH is the aero panel and where is it exactly???
0oE is offline
Old 06-28-2007, 12:10 AM   #28 (permalink)
G
Yeah, i got s.tech and they're doing pretty bad. I got all the noise going on for 5 months now, it sucks. I'ma get the Tein SS soon.
RiceBowL54 is offline
Old 07-01-2007, 11:47 PM   #29 (permalink)
My FA5 made a knocking/popping noise as well. I took it into service 3 times. First time, they changed the entire left strut. Second time they retorqued all the bolts. Third time they called Honda corporation tech line and they said to install a rubber stop. They installed it but it still makes the same noise. Then they said that this "noise" is a characteristic of the 07 SI's.
llckll is offline
Closed Thread
Anyone else experience nasty gastank slap front to back? yacoub Mechanical Problems & Technical Chat 20 01-19-2012 10:47 AM
Dumb Laws C2i0v0i1c Water Cooler 72 12-21-2011 07:45 PM
A popping sound from front passenger when turning wheel. SonicK20Z Mechanical Problems & Technical Chat 58 07-04-2009 08:52 PM
U.S. & Canadian Tint Laws jc21 Inside and Out 46 06-17-2009 05:33 PM
popping sound from right front(passenger side) sickyute Suspension and Brakes 14 11-24-2007 07:19 AM
