Who here has upgraded their rear anti sway bar from the puny 11mm stock piece to the Si 17mm bar? Or 22mm Progress sway bar?
-Aren't the rear ends (regarding the sway bar) the same? I drive an LX, I understand that I have drum brakes in the rear but I was trying to install the Si sway bar with bushings, bushings holders and brackets. I came across some clearance problems, stock axle-back and upper control arms were rubbing. - - Who has installed a larger diameter rear anti-sway bar on their DX or LX Civic? |
#2 (permalink) | |
M U K E Y
WTFBBQZ?
Oh. Not to threadjack or anything. But to those who used the Progress rear sway bars.. which bushing brackets did you guys upgrade to? The Si bushing brackets? Or is there an aftermarket alternative you guys used? Thanks for the reply and sorry to threadjack.
![]() Oh and just a side note.. I think I read somewhere that if you have clearance issues.. you probably put the bar on upside down.. so flip it around and try it again.. lol I might be wrong though.. |
Si front and rear. EX Sedan.
There's a long standing thread with some good info. Si Front & Rear Sways on an EX Sedan |
#10 (permalink) | |
WTFBBQZ?
#11 (permalink) | |
Hail corporate masters.
#12 (permalink) |
you are correct on needing all the si hardware brackets bushings and sway of course.. if you go progress it comes with a adapter to hook up to the dx/lx/ex brackets no xtra hardware needed.. i had the si front and rear, and recently swapped the rear for the progress sway.. i recommended this to any r18 owner over the stock si bar.. i dont have upgraded endlinks, no problems so far
#13 (permalink) | |
-Do you feel more of a difference with upgraded wheels tires? (225/40/18) I don't know why I couldn't do it the day earlier. I simply started to install the sway bar today and everything was falling into place. 11mm (hollow?) to 17mm solid. You really think the 22mm sway bar is that much better? Does your car oversteer more than you would like? How much for the Progress rear sway... I just put the Si bar on and you're telling me to go with the Progress sway bar because its that much better not what I wanted to hear. I am happy with my mod then someone tells me there is a better mod. Everything came out to $70 my family and friends are going to think I'm crazy if I change it again. How much would you say the Si front sway bar helped you?:) Is there an aftermarket front sway bar? |
#14 (permalink) | |
sway bar r18 question
Also as for front sway bar is it necessary to change it over stock LX? any difference. |
| Si Front & Rear Sways on an EX Sedan | iVTEC | Suspension and Brakes | 228 | 07-21-2008 04:09 PM |
| SI rear sway bar | Civic_DC2 | Suspension and Brakes | 74 | 06-24-2006 11:15 AM |
| Ordered a Progress Technology rear sway bar | Cookstar | Suspension and Brakes | 22 | 06-16-2006 02:08 AM |
| Si rear sway bar | CivNick | Suspension and Brakes | 8 | 06-04-2006 06:14 PM |
