#24 (permalink) | |
#25 (permalink) |
How much are they HFP springs and how difficult are they to install?
I do have jack stands and ramps and some basic tools but no air tools. Can the springs be installed with basic tools? Do you need a spring compressor? I am intriqued. I would like better handeling in the corners. The stock springs cause way too much body roll. Thanks for the info. Tom in Indy |
#26 (permalink) | |
It's a full kit with pre assembled front struts and springs and rear shocks and springs. Much better handling. 3 hour install. |
#30 (permalink) | |
so how is the comparison between HFP coilovers and like.... Tein Coilovers. sorry if this is a nub question -_- What's the price difference? |
#31 (permalink) | |
English Classassin
#38 (permalink) | |
Thanks.
#40 (permalink) |
Civic Suspension Specs
Body: Springs F/R lbs/in - Sways F/R mm Sedan: 140/145 - 24.2/10 (12mm rear on Hybrid) Sedan Si: TBD/TBD - 27/17 Coupe: 170/200 - 25.4/11 (DX has no rear bar) Coupe Si: - 200/230 - 28/17 Civic Coupe Exclusive Suspension Tuning... The Civic Coupe has the following exclusive suspension tuning compared to the 2006 Civic Sedan: * Front spring rate increases 20 percent * Rear spring rate increases 28 percent Civic Si Exclusive Suspension Tuning... The Civic Si has the following exclusive suspension tuning compared to the 2006 Civic Coupe: * Front spring rate increases 17 percent * Rear spring rate increases 14 percent NOW... Based on this, we have to work backwards. The Si models have a spring rate of approximately 200 lb./inch front and 230 lb./inch rear. Subtracting 17% front on my LX Coupe puts the front spring rate at about 170 lb./inch and the rear at about 200 lb./inch. Comparing the LX/EX Sedan down from the LX/EX Coupe puts the approximate front spring rate at about 140 lbs./inch and the rears at only about 145 lb./inch. This is courtesy of DakRaven. He sent this to me. |
| Which suspension best for Sedan: Si Coupe Suspension or HFP? | mikeymike | Suspension and Brakes | 17 | 02-24-2009 02:36 PM |
| HFP Suspension -- Ride? | GeezerSi | Dealership Experience | 31 | 11-30-2008 08:20 PM |
| HFP Suspension Kit...auto vs manual??? | DooD | Suspension and Brakes | 4 | 12-13-2006 09:32 PM |
| what exactly do I order for HFP suspension | palerider | Civic SI | 3 | 11-12-2006 01:24 PM |
| HFP suspension for Si and Ex | aznives3 | Suspension and Brakes | 12 | 08-01-2006 04:06 PM |
