AMR Coilovers Installed, review with pics
INSTALL: Ok I installed everything Thursday night. My mechanical resume includes I/H/E a short shifter kit, some shifter bushings and a rear sway bar and now these coilovers. Needless to say I am not the most experienced DIY mechanic. The install took me 10 hours, in my defense there was not a single scrap of paper in the box and I had to borrow the wife’s car and make a run to rent a spring compressor and I was working alone. It really was not that hard to do the real time eater for me was the constant stopping and thinking about what I was doing and making sure I was doing everything right ... that and constantly getting tools I left on the other side of the car. I took the wheels off last night and double checked all my work and everything looked good. I do have a full install how to in the works but I am waiting for a reply email from the manufacturer, I want to make sure he approves before putting anything out there. Also please note I have only been running this set up for a few days it will take months for me to be able to fully review this product.
REVIEW: I will start by saying that while installing I did rotate my tires and the fronts were in very bad shape so any claims of increased handling performance will be a little subjective. The Pros: Since Thursdays install I have driven in wet and dry conditions, and driven at speed up to 90 mph. While set on the softest possible setting the ride quality is very near to stock, so much so that my wife teased me about it not being any different. This is really an accomplishment considering that my car is at least 2 maybe 3 inches lower than stock. At the softest setting my wife and I took a road trip up to baton rouge (aprox 70 miles) and at interstate speeds I noticed none of the bounce effect some have reported at such speeds. As far as performance wise there is very little body roll, very little. When accelerating and braking the car feels incredibly solid, and trough turns there is also very little body roll, my sister said and I quote “it feels like a space ship". I decided to test it on the hardest setting last night and I managed to change my wife’s tune:twisted: . The ride was sufficiently rough enough to shake your teeth out, which on a race track I assume would be a good thing. So all in all I am very happy with this set, it can be near stock or race car hard. The Cons: This will be a small section and let me start by saying that these "cons" are either things I expected and should be expected with coilovers or simply engineering limitations. The only problem so far is that my car has a much harder time with pot holes and old or poorly maintained railroad tracks. Bumps like these feel much more serious than they used to even on the softest setting. I will also say that this dose not bother me I expected a much rough ride than I ended up with. One other thing to note is that the height of the rear of my car as seen in the pictures is at the lowest possible setting. From examining the rear suspension of my car it seems like this is a mechanical limitation of the suspension layout itself and is the fault of the way the car was engineered and not the fault of AMR. The front however I think I could almost get to touch the ground. Well that’s about it, if anyone has any questions let me know or if you just want to talk about the set up in general you can always hit me up on aim, I am usually on at work so mon - fri 8 - 4 on central time. The Pictures..... The weather down here has been shit so this is the best I could do for now :roll: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
used to be a company that bought and sold from the same manufacturers that made ksports and F2's . They have moved on from that and design their own stuff. You have to contact them through honda tech or by phone the web site is just a stub. btw got my set for right under a grand.
#6 (permalink) | |
#14 (permalink) | |
thats the plan, I dont really like big wheels. I might slam it for a photo shoot one day but its a DD so its set up for that right now. |
#15 (permalink) |
Moderator
first off let me say the car looks good and the drop is nice ....
the coilovers look good cuz of the colors ... 1. that is in no way a 3" drop ... 2. the drop u have in the back is because of the coilovers and not the design of the car .... i've had my rear wheels tucked in to where i can see only half my tire on tein flex ... so it's a limitation of the coilovers u have and not the desing of the car. 3. the 6kg is the reason ur back is not as low ... with that weak of a spring rate, the springs had to be longer hence the reason for a drop that's not that low ... by doing that u don't bottom out like on the megans when they had 6kg in the rear on short springs...
#17 (permalink) | |
not bad. at that drop height you'll probably want that range. are you going to get spacers to push those wheels out a little bit? |
#19 (permalink) | |
#20 (permalink) | |
| Installed my 10,000K HID Conversion Kit!! Pics will come soon! | FatHoMedDigNitY | Lighting, H.I.D.'s, & Neon | 70 | 09-08-2008 09:57 AM |
| Hondata heat shield installed (pics) | 954K20_SI | Bolt-Ons And All-Motor | 26 | 07-05-2007 05:23 PM |
| Installed my HFP Body Kit this weekend (PICS) | Bulld0g | Inside and Out | 67 | 06-18-2007 03:18 AM |
| Installed my 6,000K HID Conversion Kit!! Pics Included !! | monkey323i | Lighting, H.I.D.'s, & Neon | 5 | 06-14-2007 04:10 PM |
| pics of my crappy subs installed in coupe | cheebs | I.C.E., Electrical, Security, & Navigation | 5 | 06-04-2006 11:54 PM |
