A Serious Track Brakes Setup... That works!
Hi all!
I started tracking my '07 Si Sedan 4 years ago and quickly realized that the stock brake setup was easily the weakest link for good track performance (okay, behind having a good set of tires). I am writing this thread to share my experiences as my skill progressed and I demanded more and more from the car. I wish I had a better guide as I got into the hobby... so here one is... My first resource was a fantastic thread by Moose: Brake Options
Now, let me explain the problem with the stock brakes. On the street, they're fantastic! You will never have any issue engaging the ABS, and they will not heat up with any realistic street driving (even pushing). The problem reveals when you take your car out to a real track and start really pushing for LONG sessions (anything over than 10min). Further, at these extremes, almost all the weight, and consequently braking, will be on the front axle. The rear brakes are great to slap a set of Hawk HPS pads on and forget about for years. However the fronts... The stock front brake setup will overheat every time. Here are the main contributors:
And the final, and crucial restriction of the stock setup is the inadequate thermal mass of the stock rotors/calipers. The Acura TSX '06 generation has = diameter rotors, but are much thicker with 26% larger pads and calipers. This adds a ton of additional thermal mass to manage larger heat inputs. Again, this is only needed on the front axle. To complete the story, I had quite an adventure in figuring out a high performance AND economical brake pad. I would say this is equally important as switching to the TSX rotors. This is my trail:
To sum the pad journey up... If you're really pushing the car hard for extended sessions, get a pad that is rated for 1500-1600F! With the small thermal mass of the brake setup, combined with the extremely front loaded brake dist., you will need the added temperature. I think this is the main reason why the first sets of pads only lasted 2 weekends... These are great pad companies, but our car needs a more temperature tolerant compound than I chose. This is also why flushing your brake fluid with a quality DOT4 fluid is essential, otherwise you will put your foot to the floor... not good. The TSX swap is a great idea as well: cheap, easy, works great. Anyway, I hope this helps people out! I know it's kinda late, but I wish I could have read this coming into the track hobby. I am proud to say that I am running my little civic in the experienced run groups with the Audi and BMWCCA's, and still passing corvette's, porsche's, and the occasional lotus... I even have a picture of me lapping an R8 ![]() track shots from a year ago. Let me know if you all have any questions! -Mike |
Yetti 000
most def. I have hps in the rear and hp+ in the front and enjoy it for track use. however, I still need to change my fluids to find out if the pads are fading at all. for now, that fluid is the weakest link as it boils pretty quickly.
.Yetti |
#4 (permalink) | |
The rotors really aren't big enough for our Si's. Are they the same size as the rest of the Civics? Now with better pads and fluid, it is too easy to overheat the calipers. As I understand it, the seals in the calipers start to deteriorate above 400F. |
#6 (permalink) | |
Yetti 000
Once I finish out this season, I'll move to a set of brembo blanks for next year. that's all anyone really needs. |
Great info! I wish i had seen this thread before ordering my Carbotech XP10's.
I've ran 2 events with Axxis Ultimates front and back with ATE super blue fluid. Brakes felt great for the first two sessions and then the third I was really pushing it and the brake pedal hit the floor at the end of straight away. Anyways, for the next event i'm going to install the XP10's and RBF600 fluid on a stock brake system, do i have to worry about heat damaging the calipers? I've heard some people saying even thought the pad can take 1600F heat, the brake piston seals will melt and they rebuild calipers oftens. Any advice? |
Pete
Nice write up! Where do you track at? NM i see Mid Ohio. Well if you ever make it to Putnam let me know! I may do the oct 22-23rd event put on by 10 10ths motorsports
#11 (permalink) |
Matt
I installed Hawk HP+ on my Si... I'm disappointed. The fronts were new before my track weekend... and after ~100 laps at Road Atlanta I have no pads and my stock rotors are completely destroyed (large grooves and chips of metal out). Each session was about 30 minutes. I think the rotors are weaker than the pads, and now I want bigger brakes. I can't being going off on 10a because the brake pads and rotors are shot.
#13 (permalink) |
Is there anything involved with doing the TSX brake swap? Or is it a simple R&R job. Is this also including changing the rear out as well? A friend of mine has an Si and we were looking at doing some brake work, I am glad to come across this before we purchased anything. I was leaning towards the Cobalt Friction units since I have never really enjoyed the entry level Hawk pads, but loved the Cobalts. Are those HT10s just for track days or do you use them on the street?
#14 (permalink) |
KeKeKeKeViN
Wow, thanks for the great info, My friend just recently added a set of accord calipers to his EP3, works good. However I like my new DC5R brembo better. Well, my question is the touge course I run is 5.7mile uphill, and 5.8mile downhill. With yellowstuff front pads and ATE Super blue I will still have a little brake fade after 4mile/4min(usually I finish the course within 4 1/2 -5min) after on the downhill section. Do you think adding some thermal tape/wrap to the brake line would help since they are too close to the header?
#16 (permalink) |
KeKeKeKeViN
That's what my thought too, but I've done some reseach and talked to lots of people. They say the yellowstuff is very heat/brake fade resistant even though it's not a real track pad. Coudl it be my pads are glazed?
#17 (permalink) |
KeKeKeKeViN
Just came back from a 20min touge. Brake fade after the 4th mile during the downhill section as usually. Openned my hood, touched those brake lines. They aren't that hot except those right above the header/valve cover.
#18 (permalink) |
I have run at Sebring 5 times
Hawk DTC-60s in front Hawk Blacks in rear. I have HFP rotors but will be changing to blanks. I change back to my factory pads when i get home. Also tires are very important. I run Star Specs. |
#19 (permalink) | |
If your inner tire temp is hotter than your outer tire temp try reducing negative camber. If the middle of your tire is colder add 1 psi or just the opposite if its hotter. Hopefully this will help. Knowing those temps will help dial in the tires, and suspension, and if your rotors are way too hot then maybe your exceeding the limits of the pads and they could be glazing. This is typically how I go about adjusting cars for the suspension. I wish I had a long stretch of road to do my testing with like you do. Let us know how you make out. |
#20 (permalink) | ||
Yetti 000
+1 wow I thought I was actually reading honda tech and 8th gen for a second. There's clearly other limiting factors at play here. Whats the ambient temp and what tires are you squeeling with? |
| Track SETUP 17x8.5 +40 255/40 | gudauto_pow_si | Wheel And Tire Upgrades | 2 | 01-13-2012 01:49 AM |
| Time to replace brakes...opinions on this setup. | kirks07si | Suspension and Brakes | 10 | 02-09-2011 06:44 PM |
| best brakes for my setup please help! | k20powered | Suspension and Brakes | 5 | 05-10-2010 11:36 AM |
| Track Day, brakes were great. | gtracer | Suspension and Brakes | 19 | 07-02-2009 10:41 PM |
| Help with Track Setup | Chosen | Suspension and Brakes | 27 | 02-11-2009 08:51 AM |
