#42 (permalink) |
I like the ATE Super Blue or the amber equivalent Type 200 (which makes fluid changes easy to see) - high boiling, low moisture uptake. Motul RBF 600 is also high temp but I think it picks up water faster, but not a big deal since you are likely to be changing your fluids every year if you race. There's some Castrol and Amsoil high temp products as well, all hovering in the 550 deg F boiling point range.
I'd stay away from the cheap stuff at Walmart and auto store brands of DOT 4, which have boiling points 100 deg lower than the better brands, and probably suck up water like a sponge. |
#43 (permalink) | |
#44 (permalink) | |
Jason
#46 (permalink) |
![]() Join Date: Apr 2007
Yeah, I was going to ask what other SS lines are available. Blanks? We've talked pads, but what about blanks! Calipers, we talked a bit about fluids. Does anyone do this often enough you finally bought a pump? What brand?
What's your list? Pads: Rotors: Fluid: Lines: Calipers: other:
Drags are for boys. Curves are for men. |
#47 (permalink) |
Pads: daily and autox - Hawk HPS front and rear; track days - Hawk DTC 60 front
Rotors: Brembo blanks (not drilled or slotted!) Fluid: ATE Super Blue or 200 Lines: Goodridge SS all around Calipers: TSX swap in the front, stock in the rear Other: Speedbleeders (to replace the little nipple on the calipers - cheap!) all around to make fluid changes a one-man operation, and no pump needed Brake ducts: work in progress, still trying different ideas here. Pegasus 2" silicone high temp ductwork routed to the dust shields (rivet a 2" exhaust pipe stub and cut a hole). At last week's track day at Lime Rock, my instructor was driving my car and said the brake setup was definitely a high point! He made my car run through turns at speeds I didn't think possible...
#49 (permalink) |
Pads: EBC Bluestuff or Endless N45S (Front) & Ferodo DS2500 (rear)
Rotors: S2000 spec Fluid: Motul RBF600 and now RBF660 Lines: Goodridge SS Calipers: DC5 Brembos other: DIY brake ducting I keep cracking rotors on the road course in my area. Autocross and hill climb tracks are ok though. 300mm rotors is probably too small for the weight of the 8th gen civics for hard braking at racing speeds. Last edited by lukits01; 10-01-2011 at 02:29 AM. |
#50 (permalink) |
Pads: Ferodo DS2500 all around
Rotors: Stock Fluid: Motul RBF600 Lines: Stock Calipers: Stock Only autocross at the moment. Would worry about caliper temps on a road course. I saw rotor temps of 300F after 4 autox runs. |
#51 (permalink) |
Is this a good deal for the Goodridges?
Amazon.com: Goodridge Stainless Steel Brake Line Kit for Honda CIVIC 06-On;4 Line;All Rear Disc Models Incl. Si: Automotive Also, what size bleeders? More setup info? thx.
Drags are for boys. Curves are for men. Last edited by iomatic; 10-03-2011 at 06:01 PM. |
#52 (permalink) | |
Yetti 000
and this for quick bleeders |
#55 (permalink) |
Pads: f:Project Mu Club Racers r: Hawk HPS
Rotors: f: Power Slot r: Stock Fluid: Motul RBF600 Lines: Goodridge Calipers: Stock the PMU Club Racers are a great pad!! great pedal feeling, initial bite not as strong as HP+ but i prefer the more progressive feeling, even when faded these things still stop. last a good while quite noisy tho, even worse w/o the backing plates (my car sounds like a friggin freight train....) only problem flippin expensive compared to hawks, and also when out of stock be ready for a loooonnnnngg wait..... popular with the s2k guys and they are the same part number only reason why i switched to SS line cuz this happend at around 50000miles ![]()
#56 (permalink) |
I'm sorry guys for not replying... I was out of the country and apparently never got any thread subscription updates. Glad to see you all enjoyed the information.
To update on a few questions and information:
Let me know if you all have any further questions. -Mike |
#57 (permalink) |
If replacing all components of the fluids (lines, bleeders), what would be the 'correct' procedure? Would you speed bleed it all first, replace the lines, and do a couple of flushes with new fluid?
#59 (permalink) |
i was having the same problems with my car. i ran throgh the stock set up in two track days and then went to HP+'s with rbf600. i ran through those in three track days. i tried some taiwan made brake kit, they didn't even last a whole track day. so i went to tsx calibers, rotors,rbf600 motul, cobalt xr2 pads and new line. its been working grate 5 track days and counting. the whole set up cost me about 350 and the pads were the bigest cost.
| Track SETUP 17x8.5 +40 255/40 | gudauto_pow_si | Wheel And Tire Upgrades | 2 | 01-13-2012 01:49 AM |
| Time to replace brakes...opinions on this setup. | kirks07si | Suspension and Brakes | 10 | 02-09-2011 06:44 PM |
| best brakes for my setup please help! | k20powered | Suspension and Brakes | 5 | 05-10-2010 11:36 AM |
| Track Day, brakes were great. | gtracer | Suspension and Brakes | 19 | 07-02-2009 10:41 PM |
| Help with Track Setup | Chosen | Suspension and Brakes | 27 | 02-11-2009 08:51 AM |
