#21 (permalink) |
Well thanks.... the funny thing is. I don't even own a Si. A friend does, and I told him I would help him out with setting up and building his car, along with helping him out with driving skills. Waiting for my corner scales to come so we can corner weight the car.
#22 (permalink) |
KeKeKeKeViN
My tires are Firestone Firehawk Oval Indy 500 225/45/17. Tire pressure usually I run 40psi front and 28/26 rear. Ambient temperature is usually 55-60. Those tires you might not be familiar with as they are relatively new from Firestone. Bridgestone owns firestone btw. If I give Dunlop SS Z1 a B+, I would give these a B- where hankook Ventus Evo v12 is a C-. I really don't think it's my tires giving me hard time honestly. I can tell my pedal went soft noticeably after. It wasn't that I completely lost my brake, but it felt like I only had about half of the brake power. Well, I will try you tip and report back. Thanks.
#23 (permalink) | |
#24 (permalink) |
Yetti 000
And some hps or better to the rears too.
Im not familiar with those tires but I do run with slightly less pressure on the track. If I finally change the lines and fluid next track session Im hoping to identify more issues with the pads/rotors. The front rotors are starting to show signs of wear... Looking to get brembo blanks when its time Sent from my DROIDX using Tapatalk |
#25 (permalink) |
KeKeKeKeViN
Ok here my setup:
Alignment: -1.3 front, -1.6 rear 0 toe all around. Front brake: DC5-r Brembo caliper w/ yellowstuff pads and brembo blank Rear brake: stock Si caliper w/ HP + pads and Powerslot I go with my crew. ALL of us overheat our front brake, just a matter of sooner or later. These includes accord/tsx caliper w/ HP + & HPS pads, Wilwood 4 piston 12.2" w/ HPS pads, EP3, RSX-s, Prelude stock calipers w/ HPS & HP +. By the time we finish the downhill section, we can all smell the rotors. Maybe we should be looking into brake duct. We might be going tonight, I will bring my temp gun with me to see |
#27 (permalink) |
I also went with the TSX front swap and Brembo blanks, with DTC-60 front pads (HPS rear), ATE Super Blue and Goodridge SS brake lines for track days.
Speedbleeders are handy for fluid changes and when you swap pads - little check valves in the bleeder valve so you can do it yourself without somebody else pumping the brake pedal. Also, there's another thread around here on my attempts at brake ducts but I haven't run them on the track yet. |
#32 (permalink) |
@Yeti 000
Thats how my pads and backing plates look after trackdays, just goopy and melted. Not sure why your pistons are all rusted though, that shouldn't happen. Once I went from Axxis Ults to Carbotech XP10's it got worse with melted piston dust seals on the front. Trying out Ti backing plates to see if that will help prevent heat transfer |
#33 (permalink) |
Yetti 000
Yea, not sure why the pistons look like that either. I know they weren't bedded properly. The goop is just nasty. Won't use as much next time. I have been driving daily with hp+ in front for 6 months too. Not exciting when I creep to a halt in traffic and people look over thinking I dont take care of my car... Squeeeeeeeeeeekkkkkkk.
#36 (permalink) |
ALbert
Hawk HP+ should NOT be used on a road course! Ive been a Carbotech XP10 guy for a while but recently switched over to the Project Mu Club Racer pads. I feel the pmu club racer pads compete against the XP12 compound and I also noticed that they are easier on the rotors compared to the XP10 (I daily drive on the Club Racers)
#38 (permalink) | |
Yetti 000
Road course? What do you recommend? Sent from my DROIDX using Tapatalk |
#39 (permalink) |
@ Yetti 000
Summit Point is where I do most of my track days also, may have bumped into you there at the last event But I find the Shenandoah circuit to be hard on the brakes because of the long straight into the u bend then hard on the brakes again, really gets those temps up. The Main circuit isn't as bad because there is one long straight and most other areas you are light on the brakes because they are long sweeper turns, so quick tap and enter the turn. Either way you need full track pads and good fluid. Rotors and calipers should hold up. |
| Track SETUP 17x8.5 +40 255/40 | gudauto_pow_si | Wheel And Tire Upgrades | 2 | 01-13-2012 01:49 AM |
| Time to replace brakes...opinions on this setup. | kirks07si | Suspension and Brakes | 10 | 02-09-2011 06:44 PM |
| best brakes for my setup please help! | k20powered | Suspension and Brakes | 5 | 05-10-2010 11:36 AM |
| Track Day, brakes were great. | gtracer | Suspension and Brakes | 19 | 07-02-2009 10:41 PM |
| Help with Track Setup | Chosen | Suspension and Brakes | 27 | 02-11-2009 08:51 AM |
