Old 01-14-2007, 02:55 PM   #1 (permalink)
Question Where do you place the floor jack/stands when doing springs?
I'm getting ready to install some S-techs and i'm not sure where to place the floor jack and jack stands. Does anybody have pics of proper location for the front/rear? I was also wondering what the best way to load the suspension with the jack is. Can I just put a rag over the jacking pad and jack up the rotor?
'06 Hab Red Si
06k20si is offline
Old 01-14-2007, 03:02 PM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
do not jack up the motor. if you look under the car thrue the front in the middle you can see a spot to lift it same thing with the rear of the car.
Zeuceone is online now
Old 01-14-2007, 09:53 PM   #3 (permalink)
Jack points on the si are a joke.
sbmon is offline
Old 01-14-2007, 10:29 PM   #4 (permalink)
ARG can haz gold medalz?
Nomar06's Avatar
check the manual. I used the spots behing the front wheels and in front of the rears. I think the spots are also marked on the jack that comes with the car.
Nomar06 is online now
Old 01-15-2007, 12:54 PM   #5 (permalink)
Thanks for the replies, I have used the factor jack points on the sides. I thought there was a place to jack from the front/rear of the car. And what's the best spot for the jackstands, the spots where the factory jack lifts seem weak. I bought the helms manual, but only the Si supplement and it references the civic manual for the proper locations.
06k20si is offline
Old 01-15-2007, 01:43 PM   #6 (permalink)
King Bob's Avatar
Houma, Louisiana
the factory jack points are weak, thats why mine are all bent to shit but I figure you gotta break some eggs right?
King Bob is offline
Old 01-15-2007, 02:41 PM   #7 (permalink)
Nomar06's Avatar
Factory jack point do seem weak but I had no problem using them. The front and rear "middle" jack points are marked by an arrow. If you get down there and take a peek I know the front one is about a foot away from the front of the car. The arrow is molded in the plastic black peice. Cant remember about the rear jack point.
Old 01-15-2007, 02:42 PM   #8 (permalink)
Sli(ks's Avatar
Maybe they figured you'd only be using them once or twice, like on the side of a freeway changing a flat - not installing parts every other weekend.
Sli(ks is offline
Old 01-15-2007, 05:04 PM   #9 (permalink)
kenchan's Avatar
you guys using the rails near the side of the car? if so, make yourself an
adapter out of wood with a slit cut down the center. that'll prevent
the rail from bending like that.
kenchan is offline
Old 01-16-2007, 02:03 PM   #10 (permalink)
King Bob's Avatar
Houma, Louisiana
Thats exactly what I think, it dosent bother me I fugure onec they are completely bent flat they wont bend anymore
King Bob is offline
Dumb Laws C2i0v0i1c Water Cooler 56 03-19-2008 03:02 PM
People with lowering springs... How are you stock struts holding up? DumbasSi Suspension and Brakes 41 09-02-2007 09:43 AM
Mantus Lowering Springs Lek Suspension and Brakes 1 01-06-2007 05:34 AM
Suggested struts to go with Comptech springs? Toxis Suspension and Brakes 6 10-14-2006 02:07 PM
Any Springs will fit? hoanger Suspension and Brakes 11 06-07-2006 12:15 AM
