Springs with stock struts
I'm about to install my progress springs, rear sway bar, and camber kit. I figured I am cool to use my stock struts, but after doing plenty of searches on the board I've found that some people say negative things about using lowering springs with factory suspension.
Am I ok? Will the car ride ok if I use the stock suspension? Could something break prematurely? Thank you all. |
well many of us here all have new civics, and thus new struts.
so, i don't think anyone here (to my knowledge) has blown their struts on aftermarket springs yet members have said that it rides great, some have said that its kinda bouncy, but no blown struts. As far as I know, you CAN use your stock struts for now, but they will eventually get blown out faster than if you were to stay on stock suspension. I would say a year or less, depending on how you drive, how much you drive and all those crazy factors. I've had a member on another board tell me that Koni Yellows are out for our car (can anyone confirm this?) You should look around to see if you can get your hands on a set of aftermarket struts, as I haven't been in the loop for that in a while. all in all, you should be okay for now on stock struts if you really wanna get that suspension in... but replace struts ASAP if you can. |
WooooHooooo
ok, i got excited when i red that koni's are out...
tried to go to the website and there's nothin there for newer civics. the last time i talked to the people at koni, they said it'll be out mid of 07.
![]() The last time I was inside a woman was when I went to the Statue of Liberty ![]() |
>The last time I was inside a woman was when I was inside the Statue of Liberty.
hahaha. and you came out the back end? lol funny sig. i usually cut my bumpstops about 20mm when i do lowering springs. the blown strut could have been just a bad strut. my car at about 1500miles or so had a blown front strut from STOCK springs. warranty repair, ofcourse. :) |
#6 (permalink) | |
#7 (permalink) | |
almost. the question is what is the lowering spring's spring rates. |
280whp, 219tq, GReddy FTW
I have had lowering springs on stock struts before, and I don't recommend it. The ride is bouncy, and then I blew out the struts in about 4 months and it was so much worse until I bought upgraded struts. Save yourself the headaches, and spend a few hundred on upgraded struts also. You will be much happier in the end, trust me!
honda 4 life
In my EK civic I had Progress springs with an extra coil and a half cut off using the stock struts for about 6 years. The struts are still fine and the ride quality is great. Either you guys have really bad luck or bad springs or something. Stock struts won't die so easily.
#10 (permalink) |
WooooHooooo
i ran 45k on my old eclipse w/ just the aftermarket springs. nothing happened, i drive everywhere (city/hwy) w/ potholes and stuff but still good till the day i traded it.
#11 (permalink) |
if you want looks youll be fine. it will shorten the life of your struts but wont blow them out that fast. if you are going for performance get struts first. struts will do more to your car than springs. MOST people dont know this but it is a proven fact. adjustable struts/shocks are great. you can make them soft like oem for the street and daily driving. then when you want to track it you can stiffin it. i would personally go all out and go with struts also. they are a great upgrade and paired with springs with the right spring rate will deliver great performance!! just get them!
#12 (permalink) |
better tires will net you more performance vs just getting new struts
over stock springs. im planning to lower the civic for looks. it's a daily driver. struts would be nice though, to minimize undulations. im pretty sure im going to have at least a little on just lowering springs alone but considering im not going to be aggressively driving this car anyway might do the trick. plus i'll be doing the install, so no issues replacing the struts later on. |
#14 (permalink) |
^^ not necessarily true. c/o's usually come with high spring rates with
matching damp rates so might be too firm for a daily driver. want to check into that first wat rates they are offering. for stock-like ride but firmer to compensate for the reduced stroke, i would say you want something in the 250lbs/in area. c/o's are sometimes a nusance as you have so much more options to set up... im sure you'll want to corner balance your car which will require adjustable endlinks, etc. if you want to do it correctly. if you have a limited budget for this car (like me), just get springs, try it, if it's got too much undulations get struts later. make sure you get an alignment though, after you do the spring change. im looking at spending 150 for the springs, 85 for alignment. so less than 250.... pocket change. |
#18 (permalink) |
coilovers are nice to get because they are already put together and some of them have camber kits on the pillow mounts. this creats an awesome amount of adjustability. also yeah they are also offered in really high spring rates and can be too stiff for daily driving. most applications are offered in a street and race style spring ratings. look into the street ones. they will be stiff enough for you and youll have an extreme amount of adjustability still. and i agree with kenchan as he obviously knows about suspension to stay around 250lbs/in
| People with lowering springs... How are you stock struts holding up? | DumbasSi | Suspension and Brakes | 41 | 09-02-2007 10:43 AM |
| Suggested struts to go with Comptech springs? | Toxis | Suspension and Brakes | 6 | 10-14-2006 03:07 PM |
