Old 01-02-2007, 11:36 PM   #1 (permalink)
Yo Nadz's Avatar
Exclamation Cut bump stops for Eibach Sportline install?? PLEASE HELP!
I am in the process of putting a set of Sportlines on my 06 SI. The instructions say to cut 40MM off the bump stops. Is this nessecary?? Also, where are the bump stops?? Are they one the front and back, and if so do I cut both. Pics would be AWESOME if someones got them. Thanks in advance for the help!
Yo Nadz is offline   Reply With Quote
Old 01-03-2007, 01:20 AM   #2 (permalink)
honda93's Avatar
Let me show yas my Showas (shock thread)
Read the top of it carefully.
If I were you, I'd remove no more than 12-15mm (about 1/2 an inch)... The bumpstop is actually quite progressive on the shocks and will act as additional spring rate.
Anthony "Mario" Crea
NNJR-SCCA
Old 01-03-2007, 03:01 AM   #3 (permalink)
Yo Nadz's Avatar
Interesting post...... Anyone else installed Sportlines??? Did you cut your bump stops?? Also....what the hell does 40mm convert to in inches?
Old 01-03-2007, 05:08 AM   #4 (permalink)
It's about 1 1/2" & yes I've installed. It's easy..
DTurnbull is offline   Reply With Quote
Old 01-03-2007, 10:18 AM   #5 (permalink)
honda93's Avatar
Replied to your PM
Old 01-03-2007, 08:44 PM   #6 (permalink)
David
i have 2 inch drop and i havent cut the bump stops at all and i never bottom out or hit them
untouchablesi is offline   Reply With Quote
Old 01-03-2007, 08:49 PM   #7 (permalink)
airportguy770's Avatar
Dave
I installed the sportlines. I cut mine down. There was a guide in my box that I used to measure off of, a paper templet. I think if you dont cut them they bottem out, but dont quote me on that.
airportguy770 is offline   Reply With Quote
Old 01-04-2007, 03:36 PM   #8 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
I'm dropped on tein's and cut the bumpstop like the instructions said. I've bottomed out a few times
Old 01-28-2007, 08:16 PM   #9 (permalink)
japspecjohn's Avatar
John
cut the fronts here not the backs to lazy to take the shock out
japspecjohn is offline   Reply With Quote
Old 01-29-2007, 01:34 PM   #10 (permalink)
Yo Nadz's Avatar
Yeah, I only cut the fronts too, do to lazyness. LOL, no problems yet!
Old 01-29-2007, 03:28 PM   #11 (permalink)
I hate you
ILL FG2's Avatar
AJ
Cut all the bumpstops here... No problems/bottoming out yet.
"8thcivic.com where everyone holds hands, nutswings and paints everything in time attack fashion"
-Michael Bolton
ILL FG2 is offline   Reply With Quote
Old 09-09-2008, 03:49 AM   #12 (permalink)
eliptik's Avatar
Michael
what do you guys use to cut the bump stops?
eliptik is offline   Reply With Quote
Old 09-09-2008, 03:52 AM   #13 (permalink)
cambodianricer's Avatar
Jason
light saber
cambodianricer is online now   Reply With Quote
Old 09-09-2008, 05:42 AM   #14 (permalink)
radiocontrolhead's Avatar
Danny
Teeth.
Old 09-09-2008, 06:00 AM   #15 (permalink)
eliptik's Avatar
Michael
Would a regular kitchen knife cut through it or would a saw be more adequate?
Old 09-09-2008, 03:45 PM   #16 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
It's not that hard, just do it. You'll find something around to cut it. I used a box cutter.
Old 09-12-2008, 12:02 PM   #17 (permalink)
s0opa_Si's Avatar
M i l o
^ did it cut pretty smoothly?
does anyone have a pic of the bump stop on and then cuted off?
it would be a big help.
s0opa_Si is offline   Reply With Quote
Old 09-12-2008, 12:19 PM   #18 (permalink)
just use something sharp, knife, razor, saw..etc. what do you help on?
asdf is offline   Reply With Quote
Old 09-13-2008, 03:44 PM   #19 (permalink)
Kronos_32's Avatar
I cut the bump stops with a box cutter for my sportlines. it was a lil difficult but it work. My car has a popping sound when i go over some bumps in the front. WHY?!?! i cut the stops, retorqued everything, and put everything in properly. but i heard it's normal.
Kronos_32 is online now   Reply With Quote
