Carbing Upper Strut Bar Pics
I ordered a Carbing Upper Strut Bar the help complete the handling package on my FG. The installation is pretty straight forward. Here are some pics:
![]() Beautiful welded end plates, the double bolt on the endplates is a much better setup than the single bolt found on other bars: ![]() End Plates Installed: ![]() Bar Bolted back together: ![]() Last time the beautifully crafted bar will be seen: ![]() Only way to see the bar once it is installed, through the vin window: ![]() It is a shame that the upper strut bar can not be seen after installation but hey function before form. I have never been a fan of bolt together style strut bars, due to the flexing and adjustablility of that style of bar. But the Carbing bar with its dual bolt on either end plate is a very good solution to this issue. You could not install an upper strut bar on our vehicles if it was a single piece bar. That being said the Carbing strut bar does add to the high speed stability of the front end of the vehicle. When tossing the car into highway sweepers the front end tracks much better. The only issue with this bar is that it does need to be removed if you plan to do a header install or rere a valve cover. Basically anywork that requires the factory windshield brace to be removed, the strut brace gets in the ways of that. Other than that, this is a great piece I would have expected nothing less from Carbing or Tein. |
For sure. It does help the turn in of the car. The bar aids in the stiffness of the chassis. It is most noticable in high speed turn in. But on my favorite mountian road my car feels noticably more nibble on direction changes.
I have a review of the Megan braces posted also. Megan H-Brace and lower rear brace Review
The Megan lower front h-brace and lower rear tie bar did help tighten up the chassis. The did make the chassis stiffer. Not as noticable a mod on a stock suspension, but with my coil overs and my current setup it was noticable. Not a recommended first mod but definately helps. |
I order it from my local Tein dealer. You can order it through any one of the forum sponsors their pricing is pretty good. The install took about an hour and a bit. Overall not that difficult to install.
#9 (permalink) | |
#10 (permalink) |
The Megan are very good. No complaints. I just got the latest revised rear spring and I am just testing them out right now. With the new rear springs the ride height isn't an issue anymore. Bottoming in the rear isn't an issue anymore. I am trying to get some more set time before I do a full write up about the revised rears.
#11 (permalink) | |
| CUSCO 3-points Front Strut Bar **56K NOT FRIENDLY** | el_ben2 | Suspension and Brakes | 60 | 03-19-2011 03:53 AM |
| Carbing strut tower bar? | sickyute | CorSport | 45 | 07-20-2008 04:53 PM |
| Installed Pics: Front Strut and Rear Sway Bar | pengful | Suspension and Brakes | 20 | 04-14-2007 12:44 AM |
| Carbring Strut Tower Bar | 06SILVERSI | Suspension and Brakes | 20 | 12-02-2006 11:02 PM |
| Installed Pics: Front Strut and Rear Sway Bar | pengful | Suspension and Brakes | 25 | 10-26-2006 10:04 AM |
