Old 08-03-2007, 03:30 AM   #141 (permalink)
HONDACARE's Avatar
Gabe
Originally Posted by Cruzz21
The Wilwood kits on fastbrakes will fit on 17's right? Any particular offset for them to fit or doesn't fit?
yes its a 12.9" stock size rotor
HONDACARE is offline   Reply With Quote
Old 08-15-2007, 09:46 AM   #142 (permalink)
Originally Posted by mellowbob
Dude, technically that's not a BBK. That's the stock Brembo from the JDM FD2R.
SOGO is offline   Reply With Quote
Old 08-15-2007, 09:48 AM   #143 (permalink)
Just wondering ...
Does anyone take the weight of the BBK into consideration?
Old 08-15-2007, 11:21 AM   #144 (permalink)
boost1320's Avatar
Brian
Originally Posted by SOGO
Just wondering ...
alot of them are lighter because of the aluminum calipers vs. the stock ones. the rotors may be a litle heavier because of their size in some kits but not really significant enough to matter because of the material removed to cross drill or slot them. did you take that into consideration?
i agree that they are not really needed on these cars unless you have some crazy power(which no one really has yet). doing pads rotors and lines will make a huge difference.
people should be more concerned with the weight of their rims.
boost1320 is offline   Reply With Quote
Old 08-15-2007, 02:49 PM   #145 (permalink)
Andrei'sCivic's Avatar
Andrei
Just wondering ...
A lot of them are two peice rotors, with an aluminum center and of course iron/steel rotor. True... the weight is farther out now that the rotor is larger in diameter. Weight is something everyone considers especially when its reciprocating mass. Lighter calipers are only unsprung weight; the weight of the calipers matter a lot less than the weight of the rotors.
A heavy caliper wont make your car feel slower in the straight away, but heavier larger rotors will.
Andrei'sCivic is offline   Reply With Quote
Old 08-15-2007, 05:37 PM   #146 (permalink)
I guess that's why a lot of people favour the 2-piece floating rotors where I come from.
I'm actually looking at getting the Spoon BBK meant for the JDM Accord CL7/CL7R. Over here we've got a lot of folks running their FDs with Euro-R stock brakes because they're a direct bolt-on, but the stock rotors are mighty heavy (can't recall the exact weight right now, but they're 300mm).
Old 08-28-2007, 11:18 AM   #147 (permalink)
KidnKorner's Avatar
Shane
Just to let you guys know, the top brake manufacturers who offer the "cross drilled" rotors don't cross drill them. The holes are part of the rotor casting.
KidnKorner is offline   Reply With Quote
Old 09-02-2007, 08:57 PM   #148 (permalink)
aki
aki's Avatar
Semi-Si Sedan Hater
Either way, cross drilled doesn't have much real-world utility.
As for brakes from other cars, you'd have to make sure the brake torque is equivalent to the stock Si, or else you'll more than likely see brake distances increases. Bigger doesn't always mean better.
aki is offline   Reply With Quote
Old 09-12-2007, 09:19 PM   #149 (permalink)
BobbySi's Avatar
Robert Rivero
has anyone purchased the HFP brake kit ????It looks killer i have it just waitting for car to come out of shop.will be on the road in south florida.
BobbySi is offline   Reply With Quote
Old 10-01-2007, 08:41 PM   #150 (permalink)
Teh Purpul Plane™
FBFG's Avatar
Will-I-am
Is that the only kit the fits behind 17s?
FBFG is offline   Reply With Quote
Old 10-26-2007, 06:12 PM   #151 (permalink)
HONDACARE's Avatar
Gabe
will not fit stock wheels
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/23808-big-brake-kit.html
big brake kit. - Page 8 - 8th Generation Honda Civic Forum This thread Refback 02-06-2008 10:56 AM
big brake kit. - Page 5 - 8th Generation Honda Civic Forum This thread Refback 02-01-2008 12:57 AM
ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only Excelerate Excelerate Performance 78 10-07-2009 03:51 PM
Brakes (06' Si) Parts-list: Torredo Suspension and Brakes 5 04-02-2009 08:06 PM
Wildwood big brake kit group Buy.. anyone interested? boostedg35 Garage 42 07-16-2006 10:23 AM
