#101 (permalink)
![]() Join Date: Jan 2006
Marvie
so rotora and brembo ... not as good as stoptech?
design not the same or close? not starting anything here ... the more info. the better ... i u know anything about the design and habbits of rotora and brembo compared to that of stoptech... please feel free to comment ... the more info. the merrier.
#102 (permalink) |
MS Motorsports kicks ass!!!
to shed some llight on the situation...
brembo: uses in the GT spec systems a extremely large two piece drilled rotor w/ a billet alum hat center piece. this aids in rotating mass of the entire assembly. they also use a very high friction material pad to help braking performance. the caliper is a cast type multi piece 4,6,and 8 piston setup (depending on the app) w/ high manufacturing tolerances... built with specs from the race line up. also not sure if you get SS brake lines w/ this set up rotora: uses a one piece drilled and slotted large diameter rotor...its coated on areas prone to corrosion to enhance its looks. the caliper is a 2 piece cast 4 piston unit w/ street performance pads...can be upgraded w/ their ceramic race version. which can be a good/bad thing...also includes SS brake lines stoptech: uses a forged aluminum 4,6, and 8 piston set up for the caliper. includes very large rotors...can be either drilled or slotted and are a two piece construction w/ a billet aluminum hat center piece. includes high performance pads...either axxis, pagid, or bhp pads...you choose the options. also includes SS brake lines... |
#103 (permalink) |
Marvie
makes rotora sound bad... lol
#104 (permalink) |
check out wilwoods spec on their brakes...
full brake kit: http://www.wilwood.com/BrakeKits/Pages/04/index.asp for the price i like wilwoods...dependable and very excellent craftsmanship |
#105 (permalink) |
Marvie
i saw that...
but is that the exact same stuff fastbrakes use? cuz they are the only ones i know of right now with those kits.
#106 (permalink) |
Marvie
maybe i'll give stoptech another ring + email to see what's up before i take the plunge..
#107 (permalink) | |
i will call them and get the specifics on the kit the y distribute to FB
#108 (permalink) |
Marvie
#109 (permalink) | |
Kirk
#110 (permalink) | |
Brian
I don't know if Wilwood are good or bad, but I do know that unless things have changed recently, they are meant for track use, rather than street use because they lack the dust seals on their pistons to keep road grime out. If you do use them on the street, they will need a rebuild every year or two to be safe. |
#111 (permalink) | |
Brian
Do you know what sized pistons are used for each kit? That's a crucial bit of info to make comparisons. |
#112 (permalink) | |
rotora: their piston size is manufactured specifically for each veh...so i'm not sure stoptech: depending on what caliper you use the piston size will vary from 28-44 mm on the st40 4 piston unit |
#113 (permalink) | |
Semi-Si Sedan Hater
Also, there's is some debate as to the durability of cross-drilled rotors; some say rotors cracking in them are a result of poor manufacturing. Whether that's true or not I'm not sure, but I think slotted rotors are safer in general. |
#114 (permalink) | |
i'll go ahead and do my best at explaining the purpose of slotting as well...slotting also hepls in the outgassing effect as well. mainly slots in the rotors in a sense "micro-shave" the pad to help de-glaze or prevent glazing from building up. when you have glazed rotors we all know that braking performance is decreased tremendously....so most manufacturers do not chamfer or radius the edge of the slot for this reason.... the combination of both cross drilled/slotted rotors from a high quality brake manufacturer can help decrease braking distance by providing decreased brake fade along w/ better pedal firm to an extent.... |
#115 (permalink) | |
Semi-Si Sedan Hater
I disagree about a combo of cross-drilled/slotted rotors being the best. Quite frankly, cross-drilled are completely obsolete as you said, and are only there for aesthetics. If you wanted to get rid of the boundary layer glaze, you could simply get slotted rotors. Sure the manufacturing process improved, but holes still disrupt the structure of the rotor, and cause inconsistent wear on the pads. They're not worth it. Slotted w/o cross drilled seems the best for hard braking. There's good reason why cars on Lemans, JGTC and WRC don't have cross drilled rotors. Edit: hmm, it seems some kits are designed for front only, like the Stoptech BBK? I guess it doesn't need the rears then. But kits that come in 4s (front left/right and rear left/right) should be upgraded in 4s. Last edited by aki; 12-23-2006 at 04:03 AM. |
#116 (permalink) |
Marvie
i'm not going to purchase any rotor that's drilled... that i had known from day one.
i'll try to get confirmation as to if the rotoras are drilled or slotted or a combination of both ....
#117 (permalink) | |
#118 (permalink) |
Nik Sweger
comptech has the Brembo 13" kit, i think that their best one for out cars. but it is expensie, in the tune of 2600
http://www.comptechusa.com/store/product1550.html |
#119 (permalink) | |
:banned:
#120 (permalink) | ||
Marvie
i'll wait on stop tech in the mean time ... the pricing will probably be close to that of brembo ... so be it it nice to buy the bbk ... but u must remember u'll need pads every now and then too ... brembo bbk pads don't come cheap either ... lol
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/23808-big-brake-kit.html
| big brake kit. - Page 8 - 8th Generation Honda Civic Forum | This thread | Refback | 02-06-2008 10:56 AM | |
| big brake kit. - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 02-01-2008 12:57 AM | |
| ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only | Excelerate | Excelerate Performance | 85 | 07-05-2011 03:40 PM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 5 | 04-02-2009 08:06 PM |
| Wildwood big brake kit group Buy.. anyone interested? | boostedg35 | Garage | 42 | 07-16-2006 10:23 AM |
