#41 (permalink) | |
Guest
#42 (permalink) | |
#43 (permalink) | |
A few years back, Car and Driver tested front BBKs on a WRX and found that most actually offer a bit of improvement in stopping distance over even stock brakes with high friction pads and all offered better fade resistance. Stoptech was among the best and were the cheapest option. |
#44 (permalink) | |
#45 (permalink) | |
Folks are racing the Si with the OEM brakes, AFAIK. I did see they were having some issues with cracked rotors though, but racing is still far more stressful than anything you'll ever do on the street. You have Hawk HP pads, which, to my knowledge, have an upper heat limit of around 800 degrees, which is all too easy to exceed in a FF application. Axxis ultimates are good for 1000 degrees, with Cobalt GT sports good for around the same, as well as Ferodo DS2500 (which also have a thermal barrier between pad material and backing plate). Carbotech Bobcats are good for around 900+, maybe more. You ought to buy some temperature paint and spot some on your front and rear rotors at the outside edges to get an idea just how hot the brakes are getting. |
#46 (permalink) |
great information...
+ a couple.
#48 (permalink) |
www.shotimes.com/brakes/survey/brakes1.html
For anyone interested, the above link and at least 6 more following it are HTML downloads from the Taurus SHO website archive that are good info, if somewhat dated now (things like Carbotech bobcat replacing their older recommended compound "F"). The SHO is a good example of a fast, powerful FF vehicle that needs a lot of thermal capacity in the braking system, something Ford only realized later than most owners. Better yet, here's a Google cached link that still has the images and figures. http://209.85.165.104/search?q=cache...s&ct=clnk&cd=1 Another link, since it may be hard to find the cached pages: http://www.google.com/search?hl=en&l...com+sho+brakes Last edited by CZ-75; 12-20-2006 at 02:48 PM. |
#49 (permalink) |
what he said about the stoptech kit though makes sence....
but i think all the other manufacturers would do the same thing ... especially brembo... u'd think they'd have at least the same knowledge/knowhow as stoptech to produce front brake kits that don't make brake bias bad. well ... one can always get a rotora BBK for the front ... then upgrade the rear to their mini 4 pistoon caliper that is available ... that should do the trick ...
#50 (permalink) | |
http://www.caranddriver.com/features...ng-brakes.html Last edited by CZ-75; 12-20-2006 at 02:57 PM. |
#51 (permalink) | |
#53 (permalink) | |
it's for the fg2. they have the front one and the rear one... i think it's a little pricey cuz it's just a caliper kit ... and it's almost the same price as their BBKs ... but atleast u can buy a front BBK and the the caliper kit for the rear... but yes it's direct bolt on. vendor on the site has it ... i think it's either excelerate or battle endless ...
#54 (permalink) | |
http://www.mitsubishi-motors.com/cor...ety/e/abs.html http://www.faqfarm.com/Q/What_are_ABS_EBD_EPS_in_a_car |
#55 (permalink) | |
#56 (permalink) |
for some reason my mind just thinks that EBD cna distribute force the same even with a BBK ... lol... like it would just know what to do to compensate...
need to read
#57 (permalink) | |
#58 (permalink) | |
Thankyou. That was what I was wondering..... "EPD EBD: Electronic Brake Distribution (or Electronic Brake-force Distributor) - alters how much of the brake force goes to the front and how much to the rear. Cars always have more braking on front as if the rears lock before the front then the car will spin. How much braking you can do with the rears depends on how much weight is in the vehicle so EBD dynamically adjusts this balance. Without it, the manufacturer sets up the balance so the rears don't lock when the vehicle is empty which is less braking than is possible when the vehicle is full. " If that's what EBD does than won't the car be able to compensate automatically for the front BBK??? CZ-75? |
#60 (permalink) | |
LinkBack to this Thread: http://www.8thcivic.com/forums/suspension-brakes/23808-big-brake-kit.html
| big brake kit. - Page 8 - 8th Generation Honda Civic Forum | This thread | Refback | 02-06-2008 10:56 AM | |
| big brake kit. - Page 5 - 8th Generation Honda Civic Forum | This thread | Refback | 02-01-2008 12:57 AM | |
| ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only | Excelerate | Excelerate Performance | 78 | 10-07-2009 03:51 PM |
| Brakes (06' Si) Parts-list: | Torredo | Suspension and Brakes | 5 | 04-02-2009 08:06 PM |
| Wildwood big brake kit group Buy.. anyone interested? | boostedg35 | Garage | 42 | 07-16-2006 10:23 AM |
