Service Manual Alignment Specs?
Hey guys,
I did a search and read about lots of drifting to the right issues and generally poor alignment on lots of our cars. Unfortunately for me, after my first road trip, I've discovered that I also suffer from the same problem. Having been around cars for longer than I care to admit, I know the problem should be solved by a good alignment (and a little more toe-in). Can anybody that has the Factory Service Manual for the '06/'07 coupe give me the factory alignment specs for the EX? I'm really just interested in the front toe spec. Thanks! :) |
Moderator
camber front
+/- 0.30 max in the front ... factory is set at 0 camber rear - 1.30 caster in the front is 7 tow is 0.08 front and rear i think....not too sure but just set it at 0 and u'll be fine...
Moderator
see my service manual is at AJP..they lent it from me...
i'll go get it tomorrow and let u know the exact....that is if someone with it don't respond before i do.
You shouldn't have to realign your car for a minor size change, but it never hurts. If you mounted your new tires on aftermarket wheels, be mindful of their offset and hubcentricity. If you depart more a than "a little bit" from the stock setup, then an aligment would be needed.
Hope this helps... :) |
| 2006 Civic Service Manual | jehu4u | Garage | 4 | 09-08-2008 08:14 PM |
| $75 for a Service Manual? | cbstd | Mechanical Problems & Technical Chat | 35 | 05-08-2007 02:18 AM |
| 2006 Civic Si SERVICE MANUAL SUPPLEMENT PAPER | type-si | Civic SI | 7 | 08-20-2006 01:42 AM |
| Anyone have the service manual for the sedan? | yacoub | Do It Yourself Articles | 13 | 07-26-2006 01:21 AM |
| 1 more month!!! | Ep3racer954 | Garage | 14 | 11-01-2005 10:53 PM |
