Brakes (06' Si) Parts-list: - 8th Generation Honda Civic Forum
Old 12-06-2006, 04:40 AM   #1 (permalink)
Torredo
Guest
Posts: n/a
well i have the part#s in the front of me i thought
id compile a list for anyone that gives a _____?
Master cylinder & components
Power set, Master (9") 01469-sna-a00
Master cylinder assy 46100-sna-a01
Yoke, push rod (nissin) 46151-sb2-003
Seal, rod 46185-se0-003
Gasket, master power 46191-s2k-000
Clamp, tube 46407-saa-003
Pin. pedal 46512-s70-000
Cap, reserve tank 46662-s9a-003
Filter, brake resevoir 46666-s2k-003
Diaphragm 46669-s5a-003
Bracket, brake reserve tank 46674-sna-a01
Pin, lock (8mm) 46911-s70-003
Clamp D (15.5mm) 53729-671-003
Nut, hex (8mm) 94001080800s
Nut, flange (8mm) 94050-08080
Washer, spring (8mm) 94111-08800
Bolt, flange (6x12) 95701-0601208
Tube, assy, master power 46402-sng-a01
ABS-VSA modulator
Mount, rubber 57101-slj-003
Modulator assy, ABS 57110-svb-a02
Bracket, ABS modulator 57115-sng-000
Bracket A, Modulator 57116-sng-000
Bolt, mounting 57376-sna-a01
Bolt, flange (6x14) 90003-sna-010
Bolt-washer (6x12) 93403-0601208
Rear brake (Disc)
Caliper seal kit 01473-sv4-000
Bearing assy, RR hub unit 42200-sna-a52
Disc RR brake 42510-sna-a00
Caliper sub assy R. RR 43018-sna-a10
Caliper sub assy L RR 43019-a10
Pad set RR (9 clp-14s,d6272) 43022-s5a-j00
Piston assy 43215-sm4-951
Bearing A 43223-sd2-932
Spring B, Adj. 43224-sd2-931
Spring, pad 43227-sg0-013
Shaft A (R-side) 43228-sd2-933
Rod 43229-sd2-931
Piston sleeve 43233-s5a-j01
Pin A 43235-s84-a51
Spacer 43236-s04-003
Ring, retainer 43238-sf1-003
Guide spring 43241-s5a-003
Nut, parking 43243-sd2-931
Retainer 43244-sg0-003
Lever R 43245-sna-a01
Spring R return (left side) 43246-sd2-931
Arm R 43247-sna-a01
Shaft B (left side) 43248-sd2-933
Bolt adjusting 43249-s04-003
Splash guard RR 43253-sna-a00
Pin B 43262-s84-a51
Lever L 43265-sna-a01
Spring L return (Right side) 43266-sd2-931
Arm L 43267-sna-a01
Screw, bleeder 43352-sm4-951
Cap, bleeder screw 43353-sd5-003
Bolt, flange (8x22) 45240-sc2-003
Bolt, flange (10x30) 90103-sv4-003
Bolt, wheel (saga) 90113-sa0-006
Bolt, wheel (nagoya rashi) 90113-sa0-025
Bolt, wheel 90113-sm1-005
Bolt, wheel (Thai meira) 90113-s5h-005
Bolt, flange (10x53) 90163-sna-000
O-ring (63x2.4) 91352-sna-952
Screw, flat (6x14) 93600-060140h
Washer, spring (10mm) 94111-10800
Bolt, flange (6x12) 95701-0601205
Brake lines (ABS)
Hose set R FR brake 01464-sva-a00
Hose set L FR brake 01465-sva-a00
Hose set R RR brake (disk) 01466-sna-a51
Hose set L RR brake (disk) 01468-sna-a51
Pipe C, brake 46330-sva-a01
Pipe D, brake 46340-sva-a00
Pipe U, brake 46374-svb-a01
Pipe V, brake 46375-svb-a01
Pipe W, brake 46376-sna-a01
Pipe X, brake 46377-sna-a01
Pipe Y, brake 46378-sna-a02
Pipe Z, brake 46379-sna-a01
Grommet A, brake pipe 46380-sh3-000
Clip, brake pipe 46390-sna-a02
Clip G, brake pipe 46391-sda-a01
Clip, brake pipe 46391-s5a-j01
Clip, brake pipe 46392-saa-901
Clip, brake pipe 46392-scv-a51
Clip, brake pipe 46392-sna-a02
Clip, brake pipe 46393-sfa-003
Clip, brake pipe 46393-sna-a02
Clip D, brake pipe 46394-sda-003
Clip, brake pipe 46395-sfa-003
Bracket, brake pipe 46396-sng-a00
Clip, brake pipe 46397-sna-a00
Clip, pipe & connector 46398-sna-a01
Bracket R FR brake hose 46424-sna-a01
Bracket L FR brake hose 46425-sna-a01
Bracket R RR brake hose (disc) 46437-sna-a50
Bracket L FR brake hose (disc) 46438-sna-a50
Bolt, oil 46462-se0-000
Joint, brake four way 46470-sna-a01
Gasket B, oil bolt 46472568000
Nut, paint cutting (6mm) 90361-sv4-003
Clip, brake hose 90651-sv1-a01
Clip, brake hose 90651538000
Bolt, flange (8x16) 95701-0801605
Bolt, flange (8x16) 95701-0801608
Bolt, flange (6x30) 95801-0603008
Old 12-06-2006, 05:10 AM   #2 (permalink)
zspeedzkwy's Avatar
in ABS MODULATOR
just MODULATOR ASSY., ABS is different (most expensive one) $500
LX and DX is 57110-SNA-A03
EX is 57110-SNA-A53
Brake part just need hup, rotor, and caliper <--- about $500-600
master cylinder are same in 3 model(automatic) 46100-SVA-A01
manual master cylinder is same in 4 model 46100-SNA-A01
Brake line have to change
003 01466-SNA-A51 HOSE SET, R. RR. BRAKE (DISK)
004 01468-SNA-A51 HOSE SET, L. RR. BRAKE (DISK)
029 46437-SNA-A50 BRACKET, R. RR. BRAKE HOSE (DISK)
030 46438-SNA-A50 BRACKET, L. FR. BRAKE HOSE (DISK)
About $50
zspeedzkwy is offline   Reply With Quote
Old 12-07-2006, 02:35 AM   #3 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
You're going through all this trouble getting discs in the back? Why didn't u just get an EX ?
Old 12-07-2006, 02:59 AM   #4 (permalink)
ldawson77777's Avatar
or an Si...
ldawson77777 is offline   Reply With Quote
Old 04-02-2009, 01:12 PM   #5 (permalink)
RReuphoria's Avatar
Donny
Or, you could have just bought the brakes and built the LX around them with less work lol
RReuphoria is offline   Reply With Quote
Old 04-02-2009, 08:06 PM   #6 (permalink)
this might be a lil off subject. but im going to go with a big brake kit for my si and was wondering if i could give my front brakes to my girlfriend who has an lx thanks for helping out a noob =)
junchoe7 is offline   Reply With Quote
weird anti-lock brakes? carlossamano2004 Suspension and Brakes 23 10-10-2009 01:37 PM
Wondering where to find aftermarket parts from? radiocontrolhead Forced Induction And Nitrous 6 11-20-2006 10:57 PM
Early Christmas List jp2son Water Cooler 8 10-08-2006 10:39 AM
Brakes upgraded to JDM Euro R Accord brakes pengful Suspension and Brakes 32 08-19-2006 10:21 AM
8thcivic Parts Store is Open webby 8thcivic.com Site Questions/ Problems 18 12-21-2005 09:59 PM
