Old 10-04-2008, 12:27 AM   #81 (permalink)
Justin
Iv never really done any real work on my car. Iv changed The wheels when i got a flat. So with this description do you think that i could with help of DIY change my springs?
jr8801 is offline   Reply With Quote
Old 10-04-2008, 01:31 AM   #82 (permalink)
Louder than 4 F404-GE-400
Paul
Got to start somewhere, right? As long has you have a metric socket set, a jack, jack stands, and a spring compressor, you got that.
Old 10-04-2008, 01:43 AM   #83 (permalink)
Justin
DO you have to have jack stands? can you do one spring at a time without a jack stand??
Old 10-04-2008, 05:05 PM   #84 (permalink)
Paul
Yes you need jack stands. NEVER use just a jack to hold up the car. You need at least 2 jack stands. You need to have the fronts up at the same time. If you don't, the suspension will not line up when you go to re install it because the roll bar will be pulling the knuckle to far away from the bottom of the strut. Same thing, but to a lesser extent on the rear.
Old 10-05-2008, 01:08 AM   #85 (permalink)
Justin
alright guess ill just buy some. Do you recomend 2 or 4? and should i look for specific ones? Certain weight? Any special tools i need? i have a full metric tool set. screw drivers, allen wrenches. Anything else i might need? I know spring compressor.
Old 10-05-2008, 01:10 AM   #86 (permalink)
Kronos_32's Avatar
I did mines myself with help. I was a noob too. Just DIY. it's easy. if you have the right tools then get after it. F*CK paying someone $200 plus for it.
edit: jack+ two jack stands. lift up fronts then back or other way around.
Kronos_32 is online now   Reply With Quote
Old 10-05-2008, 02:44 AM   #87 (permalink)
Paul
Just a 19mm, 17mm, 14mm and 12mm (IIRC, little drunk at the moment) socket with wrench, spring compressor, 2 jack stands, jack, offset wrench and allen wrench to take off front upper mount, beer. You CAN NOT do this with out the offset wrench to loosen the nut that holds the upper mount on. As far as jack stands go, our cars way a maximum of ~3000 lbs so you need stands that support at lest 1.5 tons. If you get lucky, like me, you can find a good set on sale. Got 4 3.5 ton stands for 32 bucks, Craftsman no less.
Old 10-05-2008, 04:36 AM   #88 (permalink)
Justin
thanks man! for the offset wrench what size do i need? i might have the right size.
Old 10-05-2008, 10:36 PM   #89 (permalink)
Paul
I think its a 17, might be a 19 . Its been a long time since I needed it.
Old 10-06-2008, 01:11 AM   #90 (permalink)
BlkSi08's Avatar
Jeff
Smile
Originally Posted by imtim25 View Post
i dont know either...per tire maybe? i dont know. well i decided to use the DIY here and do it myself...maybe next week. wish me luck!
First time honda owner here and first time in modding but did managed to install my springs correctly using the DIY in here.. step by step lowering an si 06
You'll be fine bro!
BlkSi08 is offline   Reply With Quote
Old 10-06-2008, 11:48 PM   #91 (permalink)
Justin
I aswell am doing it myself for the first time! i just ordered some pro kit springs. thtey should be here next week!! im nervous hope i dont mess anything up
Old 10-07-2008, 01:16 AM   #92 (permalink)
Spence
could someone post a diy?
07civiclx2 is offline   Reply With Quote
