Sid
if your good like you say....then you should have no problem...take off the wheel, take out the two bolts holding on the caliper, remove caliper, remove old pads from caliper, compress piston in caliper, put in new pads, put caliper back in original position, replace caliper bolts...n ur done. dont forget to pump up the brake pedal before you drive.
#4 (permalink) | |
![]() If you don't feel confident doing it, I suggest you take it to a professional. |
#11 (permalink) | |
Brian
http://www.team-integra.net/sections...?ArticleID=373 Should be close enough. I suggest you have or invest in a set of 6 pt. combination metric wrenches (up to at least 18mm) and a ball peen hammer to loosen and tighten the caliper bolts with the box-end. 12 pt. suck at anything but rounding off the heads. Bungee cords (1 ft. or shorter, elastic not rubber, with small hooks at the end to hook around the spring coils while going through the caliper slot) are highly recommended as an alternative to letting the caliper hang free on the brake hose (very ghetto). An impact driver is probably a good idea to remove the rotor retaining screws and a little anti-seize recommended if you put them back in. A large C-clamp (5" or larger) will greatly help in compressing the front caliper pistons to allow the new pads to clear the front caliper. Last edited by CZ-75; 11-21-2006 at 02:21 PM. |
#13 (permalink) | |
Brian
How are you getting burnt? Honda brakes are fundamentally the same. The bolt sizes quoted in the G3 'teg install won't be the same, but everything else will extrapolate, just remember to know which pad is which and which shims are which and what order they go in. A metallic silver marker pen is good for labeling parts. An RSX-S has almost the same brakes as the Si, if you can find an install FAQ for them. |
#15 (permalink) | |
http://forums.clubrsx.com/showthread...=brake+pad+diy |
#16 (permalink) |
A couple of tips
Get the best possible pads you can afford. Better quality is definitely better. Also, buy some space rotor screws (8) just in case you strip the existing ones. You will only need to do this if you are swapping rotors though. As someone mentioned prior bungee cords are a good idea too so nothing is hanging from the brake lines alone. You should definitely bleed the brakes too, just in case. It takes very little time for the added assurance. Also remember to break in the pads too. There are steps that the brake manufacturer recommends.
| DIY: Install guide for OEM fogs... | SonicK20Z | Lighting | 1131 | 02-10-2012 03:45 AM |
| DIY: Injen CAI install on R18 (lots of pics) | peliROJO | Engine | 168 | 02-04-2012 02:53 PM |
| DIY: Comptech SS Install | NBP~FG2 | Engine | 77 | 03-24-2011 05:15 PM |
| DIY * Injen CAI install * Si | 06blaksi | Mechanical Problems & Technical Chat | 281 | 08-16-2008 05:18 PM |
| DIY install of new head unit in sedan UK/AUS | aussiebuddha | I.C.E., Electrical, Security, & Navigation | 4 | 04-04-2006 03:30 PM |
