Pre Paid Legal Associate
![]() Join Date: Jul 2006
Daniel Tam
Megan Racing: Front lower H-Brace, Rear Lower Tie (1-Piece!) REVIEW
Alright, so I just put these on and I got to drive with them for about 45 minutes. So far, performance gains, with a stock suspension, are minimal. I feel slightly a bit less body roll and I would have to say that for the $110 that I spent on this, I think it was really worth it. As far as how the product goes, it looks EXACTLY like the Cusco Type II Underbrace, even sprayed in the same color. The only difference with the Megan one is that it fits without any modification of the exhaust system at all. As far as the rear lower strut/tie, it was a tad bit difficult to install, but I had some help (2nd person definitely recommended) and the install for it took about an hour and a half.
Installation of the rear lower strut was difficult because I found out that you had to take out the plastic cover under the rear of the Si. You need to remove like 3 10mm bolts and a couple of pop off tabs. After that, be sure to have a jack handy when you remove the lower control arm bolts, because the LCA is going to fall a bit. It's a good idea to have a 2nd person there to help you, since the LCA can go out of alignment after you pull it out, and you may need someone to pull the wheel for you while you jack it back up into place. The underbrace install was straightforward and took about 15minutes. I'll try and get some pictures as soon as possible, but there is nothing to really show. The underbrace looks EXACTLY like the Cusco one. The lower rear tie looks something like this one made for the 240, except, there is a sticker in the middle that says Megan Racing.I highly recommend these inexpensive mods. I think these braces, coupled with the Progress rear sway and some sort of suspension system, could be alot better than I see now. I guess i'll be finding out soon, as I'll be putting in the Progress rear sway, as well as a set of prototype megan racing springs in a few weeks. :) p.s. if anyone is still interested in picking up a set after reading this review, hit me up on PM and i'll let you know where to pick it up for the same price I did. I also have 1 set left that i'm looking to sell, so holla if you're interested.
![]() Now recruiting for new car team members! Contact me for more info. Show quality cars only! Preferably local and a 4dr Si. Last edited by shglbmx; 11-17-2006 at 10:55 PM. |
#5 (permalink) | |
Daniel Tam
![]() Now recruiting for new car team members! Contact me for more info. Show quality cars only! Preferably local and a 4dr Si. |
#7 (permalink) | |
Daniel Tam
Daniel Tam
8thcivic Sponsor
That piece is absolutely nothing like the Cusco brace at all except for the color. It looks much more similar to the Tanabe brace which hangs low to clear the exhaust and has a bar running across the rear portion. The Cusco brace mounts around the cat rather than below it and is nearly flush to the chassis.
The rear lower tie is pretty useless on it's own as that area is pretty nicely reinforced from the factory. However, it can help when you add a larger rear sway bar. You can also keep that nice BIG factory plastic shield you removed to mount it - it just needs a little notching with a dremel to fit.
Jonathan - www.z1auto.com - 631-863-3820 GT-SPEC FENDER BRACE PRE-ORDER! http://www.8thcivic.com/forums/z1-pe...-preorder.html Check out our BLOG for: -Customer rides -New products -Original articles http://cornerbalance.wordpress.com/ |
#10 (permalink) | |
Daniel Tam
Yeah, I decided to just take that plastic piece off since I wanted to see my rear tie, lol. Good to know that it fits with it on, though.
#12 (permalink) | |
Daniel Tam
#18 (permalink) |
Daniel Tam
thanks for the feedback so far guys. pricing is still set at $110 localpickup/dropoff or + ship, for the combo (H-Brace + rear lower tie bar), so if anyone is still interested, hit me up on PM and i'll refer you to the shop.
#19 (permalink) |
When you reinstall the bolts on the LCA just remember that they are tapered at the end. I was having trouble getting the first one to start. I used a long screwdriver to allign the holes and a hammer to tap the bolt. I didnt have the foresight to call a friend before I started. Just used a floor jack to jack the arm back up and a screwdriver to pry it back into allignment. Just a tip from the unexperienced.
| Dumb Laws | C2i0v0i1c | Water Cooler | 58 | 10-03-2008 09:27 AM |
| Rear Lower Tie Brace Bar 06 civic... ebay | Way2Short | Suspension and Brakes | 6 | 12-15-2006 07:57 PM |
| Rear lower tie bar? | BLU BY U | Suspension and Brakes | 8 | 10-04-2006 01:49 AM |
