Bottoming out on Eibach Pro Kits?
Hi all,
I just experienced bottoming out using the Eibach Pro Kit Springs with stock shocks. Getting aftermarket shocks is in my to-do list but I am still waiting for those to come out in Asia. Mine is a JDM ride. I got some info from my regular forum buddies that the bottoming out issue have nothing to do with the shocks but rather that the Eibach springs are too soft. So the shortness and the soft springs is causing the bottoming out. Is this true? Appreciate those on lowered springs can comment cos we do not have too many bros have Eibachs Pro Kits installed here. Thanks. |
#2 (permalink) | |
8thcivic Sponsor
The question is, are the Japanese struts the same as the US struts the Eibachs were designed for. I have Eibach sportlines on my SI - a good deal lower than the pro-kits and I have yet to bottom out on the largest of dips as the stock struts are plenty strong enough to control the drop and have been on for almost 9 months of daily driving in NY.
Jonathan - www.z1auto.com - 631-863-3820 GT-SPEC FENDER BRACE PRE-ORDER! http://www.8thcivic.com/forums/z1-pe...-preorder.html Check out our BLOG for: -Customer rides -New products -Original articles http://cornerbalance.wordpress.com/ |
Well, I was travelling at about 90km/h when I hit a gradual downslope and rapid upslope - like riding a wave. It was definitely bottomming out cos I heard the thud of fully compressed springs from the front. I had experienced bottoming with the stock setups before with almost similar road situations but that happens only with full load - 4 passengers. This time I encountered when I am alone. There are a lot of humps on the road near my estate, so I have to go slower than normal as I know you cannot speed through those with lowered springs but this is the first time I encountered on a normal road. However, I did a thorough check and there was no tell tale sign of the rubbing against the wells or fenders. I am running on stock 16" rims.
#5 (permalink) | |
#9 (permalink) | |||
Guys, Thanks for your replies. Really appreciate it. |
#10 (permalink) |
ok....
now that you stated fronts are the ones bottoming out this eliminates the whole "spacer" in the rear that needs cutting. Now for the fronts coming down on ya... - Install wrong? - Springs not facing correct way (Eibach reads on each coil) and each coil had a # to accociate Left from right! - Did you install all the stock rubber bushings, etc..? cuz mine still have NOT bottomed out bro' |
#13 (permalink) |
too lazy to read all the posts above, but when you installed your
prokits, did you cut about 1" off the bumpstops? if not give that a shot. usually sus setups like ours require the front to be cut about 1" to provide extra stroke. unless one recommends not to cut it, give it a shot. |
#15 (permalink) | |
Thanks guys. |
#18 (permalink) | |
But can he be right though? I know certain brands and even some of the Eibach springs for other car models are not side specific. Any comments appreciated. I should've monitored the install more closely.....
#19 (permalink) |
Your mech may be right but im going off what i had
read on my install. By the instructions givin the rears did not matter but for soem reason you had to make sure the left spring went on the left shock, vise-versa.... making sure the word "Eibach and #" were facing upwards. im just trying to help out any way i can?? Last edited by Torredo; 11-27-2006 at 01:47 AM. |
#20 (permalink) | |
| Holiday Pricing and FREE HID kits!! - XenonDepot.com XMAS PROMO | XenonDepot | Lighting, H.I.D.'s, & Neon | 51 | 12-13-2006 10:58 PM |
| ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust | skittleslegend | Civic SI | 43 | 06-22-2006 07:34 AM |
| Eibach Pro Kit Install Help in Phoenix | Tigger1 | Suspension and Brakes | 3 | 06-12-2006 11:20 AM |
| Eibach pro kit pictures | pigman | Garage | 11 | 05-13-2006 10:54 AM |
