FD2R coil spring - 8th Generation Honda Civic Forum
Old 03-12-2010, 10:45 AM   #1 (permalink)
gsrr's Avatar
FD2R coil spring
does someone know where to find oem FD2R spring?
A local import shop can sell me the whole suspension + brake for 2000$(crazy) but i only need the spring.
Thank
gsrr is offline
Old 03-12-2010, 10:47 AM   #2 (permalink)
Jason
Any particular reason why you need the stock springs?
superbike81 is offline   Reply With Quote
Old 03-12-2010, 12:15 PM   #3 (permalink)
$2000 doesnt seem like a crazy price.
doesnt the fd2r have brembo all around?
DinaSi is offline   Reply With Quote
Old 03-12-2010, 09:25 PM   #4 (permalink)
Asif22's Avatar
Asif El-Mubaslat
Why not get koni shocks and lowering springs?
Asif22 is offline   Reply With Quote
Old 03-12-2010, 10:59 PM   #5 (permalink)
Asif22's Avatar
Asif El-Mubaslat
oh wait also comes with brakes..nice
Old 03-12-2010, 11:26 PM   #6 (permalink)
Jason
But you can't use it without the front crossmember and the rear subframe.
The brakes you can use, the suspension is a no go unless you have the COMPLETE Type R setup.
Old 03-13-2010, 05:32 PM   #7 (permalink)
Asif22's Avatar
Asif El-Mubaslat
hmmm doesn't sound worth it...
seems like a lot of work. You could just get a spring/shock combo and ss lines and pads
Old 03-14-2010, 07:34 PM   #8 (permalink)
gsrr's Avatar
i already have koni DA on hfp spring but i want a fixed spring with stiffer spring rate (300/350).
i would even prefer the Mugen FD2R spring but i' am realistic...
gsrr is offline   Reply With Quote
Old 03-14-2010, 08:37 PM   #9 (permalink)
Xtreme Thunder's Avatar
Joey
IIRC the FD2R springs are longer.
You are wanting to do what I have been looking into for the past year or so. I have been in contact with Hypercoil for custom oe style springs in the range of 300/450 lbs/in (or ~5.5/8.0 kg/mm), but it is not cheap. I also want to keep the HFP height, but I also need to contact KONI to see if they can shorten the shafts of the dampers as I want the springs tight during full droop.
I currently have KONI S/A mated to FA5 HFP Springs.
Xtreme Thunder is offline   Reply With Quote
Old 03-15-2010, 06:00 PM   #10 (permalink)
gsrr's Avatar
where have you found the FD2R spring are to long?
Also do you have an idea of the cost of the custom hypercoil?
thank
Old 03-15-2010, 06:05 PM   #11 (permalink)
Joey
thank
IIRC the dampers are longer, which lead me to believe the spring is also a little longer. I tried to contact a member on here several times regarding information about free length, diameter, photos, etc of the front and rear FD2R springs, but have been ignored at serval attempts.
The custom hypercoils are alot cheaper if you get a batch done, as it is expensive to retool the machine for each coil. 500-2K I was quoted, it all depends on design and such.
Old 01-19-2011, 03:44 PM   #12 (permalink)
HRsi-dan's Avatar
the anonymous Si driver.
Hey Xtreme Thunder, are there any updates on how this turned out?
HRsi-dan is offline   Reply With Quote
Old 01-19-2011, 05:01 PM   #13 (permalink)
max
are you sure? because i have the t1r b52 coilovers for the fd2 on my fg2 and it works perfectly fine.
USDMK20 is offline   Reply With Quote
Old 01-19-2011, 05:11 PM   #14 (permalink)
testify's Avatar
The angle of the front strut is probably way off and not working with the geometry in mind that both the FD2 strut and the FG2 control arms are designed for.
Just because something physically bolts up, doesn't mean it fits.
Also, I don't believe you.
testify is offline   Reply With Quote
Old 01-19-2011, 05:48 PM   #15 (permalink)
Joey
In regards to the fd2r spring?...nope, tha post was the dead-end of the research on that.
Old 01-19-2011, 06:24 PM   #16 (permalink)
HRsi-dan's Avatar
No, I was wondering about the custom hypercoils. It would be nice to have a linear rate oem style drop spring available other than just the HFP's.
Old 01-19-2011, 09:22 PM   #17 (permalink)
Joey
I had done alot of research on this in the past and had many conversations with the guys at Hypercoil and the guys at KONI-na. I had come to the conclusion it would be cheaper to go the ASR (A-Spec Racing) or Redshift route utilizing KONI dampers and Hypercoil OBD coilover race springs. The coilover springs would allow one to choose their vast variety of free length and rates with out being stuck to one rate.
With increasing the spring rate of an oe style drop spring while trying to maintain a certain height (in my case; HFP height), the spring would have needed to be shorter than stock. Witht hat being said, the shafts on the dampers would need to be shortened which added to the cost at about $100/ corner in order to keep the spring tight during full droop instances.
JDM Civic FD2R civic FD2R Civic SI 73 01-01-2012 12:53 AM
FD2R Conversion help. Varion Icaria Inside and Out 2 06-17-2009 10:42 AM
Wonder how a FD2R looks with 15"? Ronnn Wheel And Tire Upgrades 14 03-16-2009 11:51 AM
Anyone have this spoiler?? FD2R shamshe Inside and Out 27 06-13-2008 03:10 PM
H**D*T* K100 on FD2R elementracing Bolt-Ons And All-Motor 72 03-27-2008 12:29 AM
