Matt Hulsey
Why is just 1 tire bald?
I am lowered on Skunk2 Pro S and have camber kits on front and back. Yesterday I was rotating my tires and I noticed my back right tire has no tread and is bald. The wear is pretty much even but why is it so worn down and my other tires are fine?
Peter Kim
Well I had the same problem and it was due to there being a crack in my rims. The tire pressure always dropped and I didnt realize that it was the rim until I had a bald tire. Dont know for you might just be the settings on the rear wheel is different from the front. check your air pressure tho on your tire regularly. I learned the hard way
Bobby
No its not the toe. Toe is only on front tires however mine did the same d*** thing. I am yet to figure out if it was tire pressure, my driving style, or something with the car. Im going to keep a closer look on this set of tires to figure it out.
#13 (permalink) | |
Joey
Toe will eat the tire in such a way described by the O/P, bald or chopped. |
#14 (permalink) |
Ry [ the original mahfawker ]
Lmfao there's a nice sticky in the suspension area to read
Negative camber's tire appetite = small snacks over time... Toe's tire appetite = OM NOM NOM NOM NOM
#19 (permalink) | ||
Camber/caster/toe could all be out of alignment I had a right-rear-wheel out of alignment and all 3 needed adjusted. It made my car pull right quite a bit. Best wishes with the problem man |
| Shaved, trimmed or bald ????? | Cybergypsy | Water Cooler | 87 | 11-22-2008 05:15 AM |
| Long Island SI's...bald hill car show? | NIGHTHAWKSI | North-East | 9 | 07-02-2008 11:57 AM |
| Long Island Bald Hill | nyrscu268 | North-East | 2 | 02-15-2008 07:40 PM |
| bald hill meets! | HHondaZC | North-East | 10 | 07-23-2007 02:33 AM |
| Sightseeing today in the SI - picture of bald eagles | Dale_K | Garage | 10 | 02-08-2006 09:51 PM |
