Progress Rear Sway Bar Installation Question? - 8th Generation Honda Civic Forum
Old 03-12-2010, 01:21 AM   #1 (permalink)
I'm getting ready to install my Progress RSB on my 09 Civic EX.
I just wanted to make sure I have got the installation instructions down right based on all the threads I have seen.
1. Raise the car on Jack Stands
2. Take off the RSB and bolt in Progress RSB
3. Make the Corsport Adjustable Endlinks the same size as the Factory Endlinks
4. hand tighten all the bolts in
5. Drop the car to put load on suspension
6. Torque down all bolts to specified amount (around 44 ft-lb)
correct?
Thanks in advance!
imxblue is offline
Old 03-12-2010, 01:27 AM   #2 (permalink)
yomama's butt-front's Avatar
Marcus
did you order si L brackets because you will need
yomama's butt-front is offline   Reply With Quote
Old 03-12-2010, 01:51 AM   #3 (permalink)
I believe the kit from Corsport comes with it, or at least a version of it. I will check it out tomorrow.
Does it seem like everything as far as instructions is correct though?
imxblue is offline   Reply With Quote
Old 03-12-2010, 02:16 AM   #4 (permalink)
byronl225's Avatar
Byron Lee
shouldn't the progress sway bar includes an adapter for the non si? Mine came with it
byronl225 is offline   Reply With Quote
Old 03-12-2010, 02:52 AM   #5 (permalink)
Marcus
I bought one used and the jackhole must've never included them
Old 03-12-2010, 12:03 PM   #6 (permalink)
Back to the question fellas, Do I got my instructions down right?
Old 03-12-2010, 09:42 PM   #7 (permalink)
anyone?
Old 03-12-2010, 10:45 PM   #8 (permalink)
sivtecboi80's Avatar
Nick
correct?
Thanks in advance!
Yeah thats fine or you can do it on drive up ramps so that the suspension is preloaded already either way ur good to go.
sivtecboi80 is offline   Reply With Quote
Old 03-12-2010, 10:57 PM   #9 (permalink)
okay, I will do that then, that way I dont have to move the car.
Thanks!
Old 03-14-2010, 12:28 AM   #10 (permalink)
installation went fine..Progress RSB is pretty sweet....
I have the cusco 3-point strut bar which makes it even better and Im getting HFP suspension soon!
Old 04-04-2010, 05:49 PM   #11 (permalink)
odalV's Avatar
V.D.
can i we roll on the stock endlinks? i would need 2 if i get the progress sway bar?
corsport.. Notes
-Now includes RLCA reinforcement brackets for all bars packaged after April 2009!
this would fit the SI as well?
odalV is offline   Reply With Quote
Old 04-04-2010, 08:33 PM   #12 (permalink)
Vantage's Avatar
Luke
Better hurry, CCH is still having the stimdonkulous #2 sale. Fantastic prices on HFP suspension!
Vantage is offline   Reply With Quote
Si or Progress rear sway bar?? MardiGras Suspension and Brakes 0 04-22-2009 12:33 PM
Busted rear Progress Si sway bar kamikaze84 Mechanical Problems & Technical Chat 28 08-21-2008 03:55 AM
noise from rear... hfp suspension and progress rear sway bar rippars Mechanical Problems & Technical Chat 8 07-01-2008 09:42 PM
Progress rear sway bar... Jay Kincannon Suspension and Brakes 4 05-07-2007 03:13 PM
