Rack and pinion - 8th Generation Honda Civic Forum
Old 03-11-2010, 08:50 PM   #1 (permalink)
Rack and pinion
I got 16k on my car and the rack is jacked up.. I can feel it popping when turning.. I also lifted it up on my alignment rack and can feel the popping in the rack.. I have my intake tapped for nitrous.. Should I put stock intake back on.. ? Or should I leave it? It should be covers under warranty..
sjarhar is offline
Old 03-13-2010, 12:16 PM   #2 (permalink)
Hey man, glad to hear that i am not the only one to have this problem. I am also set up for nitrous with after market fuelrail, header and intake and did not want to go to the dealership.
I spent 4 hours a few nights ago to fix this "popping" sounds and was amazed at the cause of the problem.
If you jack your car up and take a look at the rack:
- There are 2 "C" shaped clamps with a "C" shaped rubber grommets that bolt down on the front of the rack, go over the rack and bolt down on the rear side.
- When i put a wrench on the driver side bracket, it snugged up then the bolt popped, free'd up and i then tightened it down all the way....
I recommend you check and make sure both bolts on each clamp a completely tight. (don't be scared to wrench on them)
These are bolts that I or anyone else besides the honda factory have ever touched, since i bought the car new in 2008. Make's me question if this is a problem from honda?
Have any other questions? let me know, but this has completely correct the "popping" sound coming from the rack in my car.
civicpr0 is offline   Reply With Quote
Old 05-25-2011, 06:11 AM   #3 (permalink)
fre$h si's Avatar
Bobby
I kno this is a old ass thread revival but I went to Honda today for the second time, first they thought my poping noise was my hfp suspension & didn't wanna do nothing bout it. I talked to a different guy today and it ended up being my rack and pinion bolts needed to be tighten. Just for anyone that mite have this loping noise when they turn
fre$h si is online now   Reply With Quote
Old 06-10-2011, 12:02 AM   #4 (permalink)
SisHaDoWSi's Avatar
Marv
I have the same problem now, glad to see there's a fix..phew thank the honda gods.
SisHaDoWSi is offline   Reply With Quote
Rack and pinion replacement PEICivicSI Mechanical Problems & Technical Chat 3 07-21-2009 10:42 PM
Ring and Pinion swap in FG2 kahnawupas Mechanical Problems & Technical Chat 10 04-09-2008 01:52 PM
Final drive gear and pinion rbsjnh Autocross & Sanctioned Drag Racing 2 12-12-2007 04:40 PM
