Tyler Hamilton
Doing Some Bracing!!
Hey guys!
i'm going to be ordering some braces within the next week. i've been looking around all winter and i think i'm going to go with Megan Racing's H-Brace and Front & Rear Lower Tie Bars. Corsport has some un-passable deals and it looks like my total w/ shipping is going to be 215.00. i've always been a huge fan of the gold suspension parts on a black car.. but the megan racing blue looks pretty sick as well. Can i get some opinions!? THANKS! |
#4 (permalink) | |
Jason
If you don't have them already, a good set of tires will help FAR more when cornering than "stiffy bars". Then I would go with a good set of shocks and/or coilovers paired with sway bar(s). Honestly, you won't notice a difference in having/not having "stiffy bars" during normal driving. They're for looks unless you get the car on an actual track/AutoX and need the more predictable feel at high speeds. |
#5 (permalink) | |
Tyler Hamilton
I'll more than likely still get the braces for the high speed cornering aspect! but other than that... WHAT THE HELL IS THE POINT OF THESE BRACES?! |
Cody
Because the new Si chassis is already stiff enough. You're not adding anything but weight with all those braces. A thicker sway bar like Progress offers definitely helps and coilovers are always an upgrade, but anything else is a waste of money.
#9 (permalink) | |
Jason
|__| for example, becoming \__/ or \__\ or /__\ Now, with how robust our Si's are, and the speeds at which normal tires can hold grip, you will NEVER see any benefit from these stiffy bars because one of two things will happen first. 1) You (the driver) will freak out and correct the car due to the "Feel" of such high speed cornering. It's a knee jerk reaction, everyone does it. Go watch someone do their first AutoX or first track day. They're slow and sloppy. 2) Your tires will lose grip LONG before the stress reaches a point where the body/frame will flex. You'll either spin out, or you'll slow down from hearing the screeching tires. Look at it like this, suspension works from the ground up. Braces | Sway Bars | Coilovers/shocks/springs | Tires/Agressive Alignment As you go up the ladder, you'll notice less drastic benefit and more "fine tuning". Without the base, the top won't have any effect. |
#10 (permalink) | |
Jason
Anecdotal evidence. When I ran my EP3 in AutoX, I upgraded the rear sway bar to the Progress one, and DOWNGRADED my front bar to the EM2 bar (IIRC, don't remember since it was 5 yrs ago). This gave my EP3 COMPLETELY different handling characteristics. Gone was the understeer that is common with FWD cars and introduced was a more RWD "feel" with the back end coming loose quite often. A huge difference with just two sway bars. Now, was it good for AutoX? Nope. I spun out far too often. Live and learn. Upgraded the tires and put on Buddy Club Racing dampers and voila...superb handling. Never needed any "stiffy bars". OP...save your money for 1) Tires, 2) Coilovers if you want to actually notice a difference. If you want bling, by all means, slap on nice shiney things lol |
#11 (permalink) | |
Tyler Hamilton
Heres my revised plan! 1.) find a really good performance tire and get my alignment PERFECT! 2.) place my coils/sway bar order 3.) bling it the f*ck up!! THANK YOU EVERYONE FOR ALL YOUR HELP! |
#12 (permalink) | |
Your car makes the most traction it will ever have sitting still in a parking lot. Body roll is always detrimental to handling. To the OP, sounds like you've got the right idea now. Proper camber, tires, a RSB, and you'll be in good shape. |
#13 (permalink) | |
I did: 1. aggressive alignment 2. tires/wider lighter wheels 3. coilovers 4. roll center adjuster 5. sway bar When I got to the sway bar, I couldn't even really gauge the difference it made; all the other mods already helped to a great extent Last edited by wowwitsgau; 03-10-2010 at 08:49 PM. |
#15 (permalink) |
Trevor Wray
Negative camber and depending on where you race possibly some Toe in for better turn in or toe out for high speed stability
#16 (permalink) |
Michael
Depends on what you want to do. The more aggressive the alignment, the more your tires will wear out.
Typically for our cars you want more camber in the front than the back for a more balanced feel. For a hybrid track/DD setup I'd suggest -1.25 to -1.5 camber up front and -1 to -1.25 or so out back, zero toe all around. |
#19 (permalink) | |
Jason
![]() Good one, thanks for the laugh. Quote:
#20 (permalink) | |
Jason
| Underbody bracing | marcusaurelius | Suspension and Brakes | 46 | 06-17-2009 08:17 PM |
| Anyone here have any experience with body bracing the unibody's. | Punisher8738 | Civic SI | 0 | 02-05-2009 08:23 PM |
| Sneak peek - GT Spec bracing | Z1 Performance | Suspension and Brakes | 19 | 12-04-2006 12:31 PM |
