#21 (permalink) | |
Adding weight to a tire in a corner does indeed increase traction, but where does that weight come from? The inside tire. The result? A net loss of traction for the vehicle. |
#22 (permalink) | |
Jason
#23 (permalink) |
Nothing to do with being tough. Don't talk about what you don't know. Simple.
Anyways, for those who are interested, here's how it breaks down: The best cornering power will always be available when all 4 wheels are equally loaded during cornering. This is of course impossible, but we try to get as close to that as possible. As soon as a car goes into a corner, the vertical loading on the tires will change, and weight will be transfered from the inside to the outside tires. This will occur no matter what you do, even if the car has no roll at all. Now, a car that does roll will compound this, as the CG will shift, with a small increase in that weight transfer. The more roll you have, the more negative camber you must have to keep that tire parallel to the road. So, it's best to limit the roll angle as much as practical. Back to the original point, a tire's efficiency drops as you ask it to support more and more weight. While it's might be making more raw traction on that one loaded wheel, it's the loss of relative traction that is a problem. Imagine 2 wheels, both with a static 500lbs on them, and say they've got good tires capable of 700lbs of traction in this state. 1400lbs of traction in total and a cornering efficiency of 1.4 (700/500) Now, transfer weight from one to the other. 700lbs on one wheel and 300 on the other. The traction on the loaded wheel has increased, but less than the amount that the traction has decreased on the other wheel. So, your net traction has dropped due to weight transfer. Hopefully that made sense... haha, might have to edit that later. |
#28 (permalink) | |
Cody
Braces can definitely work and stiffen up the chassis on older models. Just not the 8thgen. |
#30 (permalink) |
Scott
My biggest thing is why is everyone being so technical. Its not like were driving F1 cars here, going around curves at 100mph. Were driving Civics.....dont think it matters THAT much. Im with the guy saying the 8ths civics already are good solid cars when coming to handling. Some good tires and coilovers and you should be set for what your going to be doing in a CIVIC
#31 (permalink) | |
This may not be the case with the EXs and SI's because they need extra support for the sunroof, but when my body starts to roll around a corner I can hear the chassis start to crackle and pop. So would you honestly suggest that these braces are useless for me? Edit: I also have plans to strip out many pieces of my car to lighten it up. Are you saying that I shouldn't brace when I start doing this as well? Last edited by Mehoron; 06-21-2010 at 06:45 PM. |
#32 (permalink) | |
Cody
#34 (permalink) |
I can't take SIs or EXs around a track, the SI is a bit too front heavy due to the few hundred pounds extra for the engine and has LSD which is not so great for a track. Both have sunroofs which are a no no on a track, I need to either tape both sides up with cardboard or replace them with a shell which is something I don't want to go through for a crappy 200cc extra of engine displacement, which means that a stripped out Civic LX is a better ticket for a track and cornering.
#35 (permalink) | |
i can't tell if you are joking or not for the majority of that post... |
#36 (permalink) |
rori ( f*ck your form ) <3
This is coming from a guru suspension tuner for evos, but he said that there are select braces that DO help. I do not believe the civic is a more rigid vehicle by a drastic amount if at all. The three i remember of the few were rear strut bar, front underbody brace, and fender braces.
Now he just tunes suspensions for time attacks and tracking, so i'm sure his word doesnt mean too much, but i'll take his word =]. Also dont forget that while there are braces that dont do jack, they may change the FEEL of the car allowing 90% of us drivers who are complete noobs to push the car more with comfort, which in fact does improve the speed of the car simply due to the driver. hope it makes some sense, its late. |
| Underbody bracing | marcusaurelius | Suspension and Brakes | 46 | 06-17-2009 08:17 PM |
| Anyone here have any experience with body bracing the unibody's. | Punisher8738 | Civic SI | 0 | 02-05-2009 08:23 PM |
| Sneak peek - GT Spec bracing | Z1 Performance | Suspension and Brakes | 19 | 12-04-2006 12:31 PM |
