Brake Fluid, prefrences? - 8th Generation Honda Civic Forum
Old 03-09-2010, 07:55 PM   #1 (permalink)
GZprice's Avatar
Ryan
Sup everyone, time for another question. I recently found out in my automotive
classes that my FA5 needs new my brake fluid, and didnt realy know what to get.
One guy said that penzoil was good, but i'm not putten that in my car, so the
question is what do you prefer? Performance brads, personal preference, or just straight from Honda?
I know 8th knows what there doing cuz they turned me onto Asmoil and thats as good as it gets. So any help would be appreciated, and thanks for reading.
GZprice is offline
Old 03-09-2010, 08:02 PM   #2 (permalink)
galaxygrey13's Avatar
Antonino B. B. Leyva
there is one called bluedot i think. i hear its good.
galaxygrey13 is offline   Reply With Quote
Old 03-09-2010, 08:31 PM   #3 (permalink)
mohouse's Avatar
Mo
Motul RBF600 Synthetic DOT 4 Brake Fluid
http://i101.photobucket.com/albums/m51/jrmartinez24/Ricky/c1312c1a-1-1.jpg
mohouse is offline   Reply With Quote
Old 03-09-2010, 09:10 PM   #5 (permalink)
Ayodog's Avatar
rori ( f*ck your form ) <3
Minimum you should do is ATE super blue dot4 fluid. Cheap too, two bottles will run you 25-30$ tops and if you're good, one bottle is enough for a change.
A little more expensive is motulrbf600 or w/e it'll cost twice as much but is a better choice if you plan on doing some intense mountain runs or a little bit of track.
If that isnt good enough for you then go with project mu or endless brake fluid. That stuff will last multiple track days. But at a price of course. I use project mu ^^
Ayodog is offline   Reply With Quote
Old 03-09-2010, 09:22 PM   #6 (permalink)
GZprice's Avatar
Ryan
Nice, looking into MOTUL. Its just a daily driver now. But acouple of things.
1-is Dot 4 okay for my system?
2-do you need any special hoses or parts when adding synthetic fluid?
and any other tips from you guys who switched from reg. Honda fluid to upgraded, thanks alot for the info
GZprice is offline   Reply With Quote
Old 03-09-2010, 09:28 PM   #7 (permalink)
trickyazn's Avatar
ate super blue for mild track
motul rbf for track.
Old 03-09-2010, 11:33 PM   #8 (permalink)
the honda stuff is fine unless you race
vtec_tech_06 is offline   Reply With Quote
Old 03-09-2010, 11:40 PM   #9 (permalink)
Ayodog's Avatar
dot4 is just fine for daily driving, no special things need be done about the change.
Old 03-11-2010, 04:54 PM   #10 (permalink)
20civic07's Avatar
ghetto fabulous
ate superblue for some track use and street
20civic07 is offline   Reply With Quote
Old 03-11-2010, 06:10 PM   #11 (permalink)
RGV-SI-'s Avatar
Trevor Wray
I use motul rbf 600
RGV-SI- is online now   Reply With Quote
Old 02-18-2011, 08:31 AM   #13 (permalink)
purplemonkeydishwasher's Avatar
Nishan Perera
I was running rbf600 but switched to ATE superblue. RBF600 absorbs a crap load of moisture very quickly and for what it does, unless you are a hardcore tracker, you will never get that fluid anywhere near its boiling capacity.
It's super expensive (ran me 50 bucks for 2 bottls here in Canada) and I felt the brakes get progressively spongy after two track days. Also, because of its water absorption properties, it doesn't have a very long shelf life and can actually go bad in the bottle too (or so I've heard anyway)
ATE superblue I think is the best bang for the buck, plus it comes in two colours (yellow and blue) so it makes changing your fluids way easier and mroe efficient.
purplemonkeydishwasher is offline   Reply With Quote
Old 02-18-2011, 08:56 AM   #14 (permalink)
BlackSixSpeed's Avatar
Chris
I use this as well.
BlackSixSpeed is offline   Reply With Quote
Old 02-18-2011, 03:29 PM   #15 (permalink)
I wouldn't use Motul RBF600 if you don't go to track and you don't want to replace the brake fluid often.
I am actually just switched from OEM to Motul DOT5.1....i think this is a good alternative.
crazyazn is offline   Reply With Quote
Old 02-18-2011, 04:29 PM   #16 (permalink)
FALer's Avatar
Haywood Jablomi
Valvoline Synthetic DOT4 is the best bang for the buck, since most auto parts stores should carry it and it boils dry around 500 F.
Old 02-19-2011, 01:02 PM   #17 (permalink)
Jason
DOT5 is not for our systems and will cause problems, not sure problems it would cause but I know you don't put DOT5 fluid in a DOT3/4 system.
I just flushed my brake fluid out yesterday with prestone dot4 because that was the best the local shops sold.
JEBSi is offline   Reply With Quote
Old 02-19-2011, 01:17 PM   #18 (permalink)
FALer's Avatar
Haywood Jablomi
DOT 5.1 isn't a problem.
Old 02-19-2011, 02:23 PM   #19 (permalink)
Jason
oh ok.
Old 02-19-2011, 04:01 PM   #20 (permalink)
FALer's Avatar
Haywood Jablomi
oh ok.
Yeah, DOT 3/4/5.1 are all miscible/compatible with each other, being glycol ester and not silicone based.
Brake fluid GoHuskies Civic Hybrid 9 03-05-2010 12:38 PM
fluid capacity power steering and brake fluid jsupetran Mechanical Problems & Technical Chat 4 01-24-2010 11:33 PM
Brake Fluid Question Deci Mechanical Problems & Technical Chat 3 04-22-2009 04:11 PM
Brake Fluid question dennisc Suspension and Brakes 5 09-04-2007 02:21 PM
Brake Fluid unplugged Suspension and Brakes 2 03-22-2007 02:30 PM
