suspension issue - 8th Generation Honda Civic Forum
Old 03-08-2010, 09:48 PM   #1 (permalink)
yoooooo's Avatar
suspension issue
hey guys.
i have a problem, or i think i have a problem on my Front passenger side suspension
i have the koni struts/neuspeed springs.
and when i hit like any type of bumps or pot holes the front passenger one makes a loud pop kind of noise. help!
yoooooo is offline
Old 03-08-2010, 09:56 PM   #2 (permalink)
Xtreme Thunder's Avatar
Joey
Has the suspension made the noise from the beginning?
How long suspension been in?
Are KONI inserts tight?
Are Tophats tight?
Are Lower mounting bolts tight?
Are the 3 upper nuts tight?
FSB endlink nuts tight?
Xtreme Thunder is offline   Reply With Quote
Old 03-10-2010, 06:47 PM   #3 (permalink)
yoooooo's Avatar
i checked my suspension today, i checked the top 3 bolts and the other bolts, and not sure whats still wrong.
suspensions has been in for a while. my car has 11k miles on it, and probably 6k with the new suspension.
yoooooo is offline   Reply With Quote
Old 03-10-2010, 07:29 PM   #4 (permalink)
FattyMcJ's Avatar
Jason
Check the endlink on your sway bar. Mine busted on my EM2 during an AutoX run and made the same noise until I replaced it.
FattyMcJ is offline   Reply With Quote
Old 03-10-2010, 11:09 PM   #5 (permalink)
how long have you been hearing this noise? Did you remember to check the bolts that hold the shock into the housing.
sleeper_civic is offline   Reply With Quote
Old 03-11-2010, 08:09 PM   #6 (permalink)
yoooooo's Avatar
ok so i checked the 5 bolts on top of the strut adjusting area. 3 for the struts and two bolts next to them(not sure what they are)
not sure what to check on the bottom side. i didnt install the struts so not sure and im far far away from the mechanic who did.(military).
Old 03-11-2010, 08:35 PM   #7 (permalink)
did you check the one in the center of the strut hat?
Suspension issue 91EclipseGS Mechanical Problems & Technical Chat 23 10-28-2009 06:49 PM
Suspension issue kris5597 Suspension and Brakes 31 09-09-2009 09:49 AM
Help: Rubbing Issue with hfp suspension in the rear Ta Fetty Wheel And Tire Upgrades 8 07-30-2009 04:39 PM
HFP Suspension Issue Blk_07_SI_Sedan Suspension and Brakes 23 03-20-2009 03:21 PM
Another front suspension popping-griding issue wbcooksey Mechanical Problems & Technical Chat 4 04-30-2008 10:13 PM
