questions about ground control coilover - 8th Generation Honda Civic Forum
Old 03-08-2010, 05:00 PM   #1 (permalink)
does anyone using the gc coilover now and is it good for use on the yellow koni shocks? also i have a question is i don't know how many inches they drop, on the ebay they all said it between 0.5"-2.5", but i know sometime those ebay seller just copy other car's infomation so maybe not corrert, i had check their website and got a really "detail" info (Ground Control - 2006-up Honda Civic Si). so...anyone know the gc coilover's detail infomation? thanks.
xbcyl is offline
Old 03-18-2010, 01:22 AM   #2 (permalink)
I would also like to hear from a few people that are using/used GC's I've read other posts about the rear springs poping out etc etc. I just want to know if they ride smooth or at least equivalent to factory si suspension.
kevhonda is offline   Reply With Quote
Old 03-18-2010, 01:28 AM   #3 (permalink)
Hope someone can come up with this info. Really interested in how much the drop is f/r with the springs at the highest setting.
sleeper_civic is offline   Reply With Quote
Old 03-19-2010, 12:41 AM   #4 (permalink)
from what i remember they can drop you A LOT, if you take out the perches and lock rings
but if you don't want it that low i believe it will drop you low enough to tuck (some) tire on 17s. How low that is exactly i cant tell you
Kevin P is offline   Reply With Quote
Old 03-19-2010, 07:28 AM   #5 (permalink)
there was a person on here using GCs off an EP3 and seemed to be doing OK, but that was a while ago and I dont know where that thread went
the stories of springs not being fully seated at full droop is enough to scare me though
VTEC_4_LIFE is offline   Reply With Quote
Old 03-19-2010, 07:48 AM   #6 (permalink)
Jardiniboy's Avatar
Jasten
His shocks went out pretty fast. Now he's on buddy clubs.
Ground control needs to reconstruct the springs for our cars because the rears are just too short. That's the reason why when people jack up the rear of their cars, some just pop out.
Old 03-20-2010, 10:50 AM   #7 (permalink)
I have the GCs on my 07 Si Sedan. I have them set at pretty much the highest ride height I can and they are still pretty low IMO. I am just about to start researching what other springs I might replace them with to get a little more stock ride height (long story...road trip, tire wear, etc). I'd think there should be some other springs that I could use but I'm not sure yet.
As for ride comfort, they are a tiny bit stiffer than stock as I have them set. That's for just normal driving on decent roads. Get on a bad road and you can definitely tell the difference. I try hard to avoid any serious bumps/holes because I bottom out pretty easily even after trimming the bumpstops as per the instructions that came with the GCs.
Overall, I do like them but as others have mentioned the rear springs are definitely too short. And yes, when the car is off the ground those rear springs do pop out.
Deadpool_25 is offline   Reply With Quote
Old 09-30-2010, 11:43 PM   #8 (permalink)
2fly4nysi's Avatar
kris
i was also thinking bout getting these but i dont know anymore i dont think i can deal with that popping out issue
2fly4nysi is offline   Reply With Quote
Old 10-01-2010, 08:26 AM   #9 (permalink)
Xtreme Thunder's Avatar
Joey
Get a longer rear spring. Easy as that. ...oh wait, then the next thing will be they can't dump it 2.5"+ or something!
In reality, use a longer rear spring. You will have more spring travel, but will not be able to go as low, but you will yied better handling when not dumped anyway.
Xtreme Thunder is online now   Reply With Quote
Old 05-26-2011, 04:17 AM   #10 (permalink)
matt
ok so i creep on this page about once or twice a day. and i have been searching for info on ground control coilovers and keep hearing this stuff about how they can pop out if you slam your car. so what if you dont slam it. say you give it a 1 or 1.5 inch drop? do you still have a chance to lose a spring? and is there any one who can throw up some pics? i wanna see these things plz ^_^
Hg Garf is offline   Reply With Quote
Old 05-30-2011, 01:12 AM   #11 (permalink)
Jardiniboy's Avatar
Jasten
You would need to order a custom set of springs for our cars to solve that problem.
The spring that they made for 06-2011 civics are too short period.
Old 05-30-2011, 01:39 AM   #12 (permalink)
EuphoricRhythm's Avatar
i would get the redshift setup that is like the gc if your looking to go that route.
EuphoricRhythm is offline   Reply With Quote
ground control jmetzer03022 Suspension and Brakes 1 02-26-2010 02:00 PM
Ground Control Coilover Sleeves x3kenster Suspension and Brakes 5 04-14-2009 11:33 PM
ground control andywho Suspension and Brakes 43 07-24-2007 12:16 AM
ground control? jb07si Suspension and Brakes 3 04-05-2007 03:48 PM
