What am i missing in this suspension setup? - 8th Generation Honda Civic Forum
Old 03-08-2010, 11:11 AM   #1 (permalink)
HFP si suspension
progress RSB[new version]
front camber kit
skunk2 rear camber arms.
BFG KDW for tires.
DinaSi is offline
Old 03-08-2010, 12:30 PM   #2 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
"Stance"...The new jockstrap
You really don't need the camber kits for the HFP suspension, unless you're trying to run some more camber for the track. The HFP setup barely drops the car at all.
Old 03-08-2010, 12:32 PM   #3 (permalink)
asianskater91's Avatar
david
the stock si camber is already more neg then we already need and .7inch drop will jus make it more negatory lolol...seriously tho
asianskater91 is offline   Reply With Quote
Old 03-08-2010, 03:05 PM   #4 (permalink)
davecivic91's Avatar
not much at all... maybe more aggressive pads? im running about the same thing as you and the things different is i have much stickier tires (dunlop z1 star specs) and they are a bit wider (225s, actually does make a little difference) coupled with konig feather rims. theyre more lightweight making handling also a bit better. look into making your tires wider and lighter rims.
davecivic91 is offline   Reply With Quote
Old 03-08-2010, 06:56 PM   #5 (permalink)
im in the process of sourcing some kosei k1's, apparently its all the rage with miata and mini guys for auto-x.
DinaSi is offline   Reply With Quote
Old 03-08-2010, 09:13 PM   #6 (permalink)
Vantage's Avatar
Luke
I dont believe they make K1's in a fitment for our cars.
I ran K1's before on my old CRX, great light and strong rims.
If you want to stick with Kosei, check out the K1-TS, very very light but IMO not as good looking as the oldschool K1's.
Vantage is offline   Reply With Quote
Old 03-08-2010, 11:18 PM   #7 (permalink)
FALer's Avatar
Haywood Jablomi
You need a camber kit any time you want to dial in negative front camber to help handling, which should be always if someone is spending money to improve their suspension.
Old 03-08-2010, 11:42 PM   #8 (permalink)
Ayodog's Avatar
rori ( f*ck your form ) <3
pads/fluid, bushings, better strut/spring setup, better/wider tires. Weight?
Ayodog is offline   Reply With Quote
Old 03-08-2010, 11:49 PM   #9 (permalink)
vf1si's Avatar
Bow chika bow wow
End links? Alignment?
vf1si is offline   Reply With Quote
Old 03-09-2010, 02:59 AM   #10 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
I'm well aware of that fact, which is why I said, " unless you're trying to run some more camber for the track".
OP: I don't know how you feel about multi spoke wheels, but you might want to look into a set of Team Dynamics. They're light, not terribly expensive, and have been used in racing for years.
Old 03-09-2010, 11:41 AM   #11 (permalink)
that car looks amazing, where did you get the red ivtec decals?!
Old 03-09-2010, 11:54 AM   #12 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
I don't know about amazing, but I appreciate the compliment. I got them from a site sponsor:
GrafiXpressions - Express yourself in vinyl form!...
Old 03-09-2010, 04:41 PM   #13 (permalink)
FALer's Avatar
Haywood Jablomi
Why save more negative camber just for the track? It helps on the street too.
Old 03-10-2010, 02:27 AM   #14 (permalink)
CHOO-CHOO!!!!!!
mattsbobo's Avatar
You're right, but most of us can't afford to prematurely use up our tires with the added inside wear.
Old 03-10-2010, 04:10 PM   #15 (permalink)
i cant find it on the list... any chance its a custom graphic?
New to suspension work, need help picking the right setup Entarl Suspension and Brakes 15 06-11-2009 11:11 PM
Suspension / wheel setup itsmeryanb Suspension and Brakes 12 12-28-2008 02:35 AM
question regarding suspension setup(just your opinion)lol manyak_si Suspension and Brakes 16 11-22-2008 09:32 PM
New suspension setup skinsfn36 Suspension and Brakes 21 11-10-2008 06:15 PM
Which is the best suspension setup? pitchblkcivic Inside and Out 11 08-20-2007 12:49 AM
