quick spring install question - 8th Generation Honda Civic Forum
Old 03-04-2010, 10:30 AM   #1 (permalink)
UltraSi's Avatar
Dave
i just installed some skunk2 springs and on the front shocks, there is an arrow on the top of the upper perch that mounts to the chasis, and im not sure which way its supposed to point. Any idea guys?
UltraSi is offline
Old 03-04-2010, 10:53 AM   #2 (permalink)
Xtreme Thunder's Avatar
Joey
Dave, IIRC, make sure it is pointing to the Engine/ Front.
Xtreme Thunder is online now   Reply With Quote
Old 03-04-2010, 01:17 PM   #3 (permalink)
JDM_FG2's Avatar
Jacob
and correct me if i wrong but if you bolt the top hat into the car it will face that way eityher way
JDM_FG2 is offline   Reply With Quote
Old 03-04-2010, 04:13 PM   #4 (permalink)
UltraSi's Avatar
Dave
good cuz thats how it did it...but now im getting a noise from the front...i un-istalled and re-installed them this morning to make sure all was tight and im still having this noise, its driving me nuts! Any ideas?
UltraSi is offline   Reply With Quote
Old 03-04-2010, 04:56 PM   #5 (permalink)
Joey
Dave, can you describe the noise as best as possible?
Old 03-04-2010, 06:44 PM   #6 (permalink)
UltraSi's Avatar
Dave
its like a loud clicking like noise...only happens when i go over a bump, not a dip in the road
Old 03-05-2010, 09:50 AM   #7 (permalink)
Joey
Sounds like something is loose. Did you tighten the three upper nuts when all load was on the suspension? The single tophat nut is fully tight, but not over tight? 2 Bolts on the lower macpherson assembly tight?
Old 03-05-2010, 10:17 AM   #8 (permalink)
UltraSi's Avatar
Dave
everything is tight for sure...whats the torque specs on the single top nut?
Old 03-05-2010, 10:24 AM   #9 (permalink)
Joey
IIRC 33 ft-lbs
Old 03-05-2010, 11:36 PM   #10 (permalink)
UltraSi's Avatar
Dave
hmmm....im sure its tight i used an impact to tighten it
Old 03-06-2010, 11:10 AM   #11 (permalink)
Joey
Should be fine then.
Just to clarify, on the 3 bolts on the top, did you make sure you did the final torque when everything was off the jack stands/ lift?
Old 03-06-2010, 06:13 PM   #12 (permalink)
UltraSi's Avatar
Dave
yep...i cant fig out what the hell it could be...ill get an alignment and see if that helps...thanks for all the help!!!
Old 03-06-2010, 08:39 PM   #13 (permalink)
I also have a clicking noise going over bumps or dips. I was told it is the coils tapping against each other.
neoguri is offline   Reply With Quote
Old 03-06-2010, 08:55 PM   #14 (permalink)
I have had that same problem in the past ad it was either the top hat nut or the sway bar endlink loose. Except the last time with my my current car (08 Si) where it was the nut that goes into the bottom of the Koni insert that was loose. This drove me nuts looking for it as I'm just not used to having a bolt in that location and I never checked it because I'm sure I tightened it with loctite.
sleeper_civic is offline   Reply With Quote
need some help with spring install bulit184 Suspension and Brakes 2 04-19-2009 06:03 PM
Quick Question...Spring Lowering and Rims NKarigan Suspension and Brakes 3 12-19-2008 02:39 PM
A quick Progress Spring review! david3558 Suspension and Brakes 15 10-12-2008 12:36 PM
Spring install bLaCkFA5 California South 2 10-01-2007 03:10 AM
