Russ
front camber adjustment.
What is the best way to adjust it? like i know you can get ingalls 14mm Fastcam bolts but is their a better way? if not do other companies make better bolts that adjust more? i am trying to search but i am at work so i can only spend so much time on here
![]() i am getting the skunk 2 V2 rear camber arms and i am trying to find what is best for the front. my setup is HFP with tein s-techs. i know i could probably go without camber stuff but i have new tires and it already needs a alignment so i thought i would get all my stuff on and do it all at once. |
#7 (permalink) | |
Joey
Adding more negative camber in the front than the rear will introduce more favorable handling characteristics by dialing out some of the stock understeer for the more favorable oversteer. |
#10 (permalink) | |
Jacob
#15 (permalink) |
Haywood Jablomi
SPC part # is 81260: SPC Application Search - Product
Ingalls part # is 81260: 81260 - 14mm Fastcam Bolts, Pair - Ingalls Engineering Co., Inc. Coincidence? |
| Range of adjustment with FOUR front camber bolts? | ultra spikey | Suspension and Brakes | 15 | 08-28-2009 01:32 AM |
| Flex Camber Adjustment | mbringle | Suspension and Brakes | 7 | 02-01-2008 09:26 PM |
| camber adjustment with s-tech? | SPORT injected | Suspension and Brakes | 2 | 05-13-2007 04:49 PM |
