changing front struts need help pls - 8th Generation Honda Civic Forum
Old 03-01-2010, 02:54 AM   #1 (permalink)
Hot_Chocalate25's Avatar
Hey guys i got skunk2 suspension on my car. I decided that i want to go back to my stock suspension. i didnt install the skunk2 suspension but I want to switch it out for my stock suspension. I tried to do the swap today but ran into a problem. I got the skunk2 suspension off just fine but I dont see how to install the stock suspension given that it is about 4 inches longer then the skunk2's. So i got the 3 screws of my stock suspension screwed up top but i dont see how to get the bottom parts to match up with the wheel because my stock suspension is way longer. So what am I missing out on? Thanks
Hot_Chocalate25 is offline
Old 03-01-2010, 08:33 AM   #2 (permalink)
Xtreme Thunder's Avatar
Joey
Jack up the whole front of the car. You are fighting the FSB if you jacked only one corner at a time.
Xtreme Thunder is online now   Reply With Quote
Old 03-01-2010, 09:08 AM   #3 (permalink)
redsled's Avatar
Yeah, that. If you put both front corners on jack stands it will be much easier. Also, I find using a second jack (if you have one available) placed under the brake to keep the axle from popping out.
redsled is offline   Reply With Quote
Old 03-01-2010, 05:29 PM   #4 (permalink)
oh that makes sense. The axel or wheel part that the struts connect to should come down more if both front wheels are off the ground?
Hot_Chocalate25 is offline   Reply With Quote
Old 03-01-2010, 11:09 PM   #5 (permalink)
redsled's Avatar
Yeah - if both are off the ground it will be much easier. Also, if your lowering the car, having an extra jack helps to get the knuckle (where the bottom 2 bolts of the strut are) high enough to get the bolts to slide in.
I hope that helped!
having NO front plate going to be useless soon... pls read itsAngeloDC5R California North 35 01-07-2009 02:33 AM
Front Struts heron126 Civic SI 3 05-21-2007 11:10 AM
Front Struts caveman74 Suspension and Brakes 2 10-23-2006 10:56 PM
