Difference between Coupe and Sedan Suspension? - 8th Generation Honda Civic Forum
Old 02-28-2010, 04:15 AM   #1 (permalink)
DonutStud562's Avatar
Sorry I just need a real quick answer... I tried searching with no luck... Can anyone tell the difference in the Si coupe and the sedan suspension?... my main concern is the rears...
Are the rear shocks the same length?...
Are the springs the same length or is the preload in the springs different the only difference?...
Please and thank you for your help...
DonutStud562 is offline
Old 02-28-2010, 08:37 AM   #2 (permalink)
jasyatz's Avatar
Shocks are the same design, different valving will fit. Springs are same size different rate and also will fit..
Hope this answers your question.
I can't remember whether the sedan springs were more or less stiff than the coupes. But I think the rear shocks on the Sedan are more aggressively valved than the Coupe
jasyatz is offline   Reply With Quote
Old 03-01-2010, 06:37 AM   #3 (permalink)
Thanks for the response bro... any one else have any input...?
DonutStud562 is offline   Reply With Quote
Old 03-01-2010, 07:54 PM   #4 (permalink)
hoserama's Avatar
My response would have been the same. There are differences in the spring load rating but everything else is the same.
hoserama is offline   Reply With Quote
Old 03-02-2010, 02:00 AM   #5 (permalink)
Thanks for responding... definitely helped out...
08 Si Sedan, suspension height difference b16er Civic SI 0 03-12-2009 06:48 PM
Which suspension best for Sedan: Si Coupe Suspension or HFP? mikeymike Suspension and Brakes 17 02-24-2009 02:36 PM
Sedan si suspension would fit si coupe? mierzwa2 Suspension and Brakes 1 04-22-2008 02:32 PM
Difference bettween Si sedan and Si coupe intake vietnati0nz Bolt-Ons And All-Motor 2 06-26-2007 05:55 AM
are sedan suspension and coupe suspension interchangeable? iqbbang Suspension and Brakes 0 05-27-2007 07:59 PM
