RSB help. I am confused. - 8th Generation Honda Civic Forum
Old 02-27-2010, 07:34 PM   #1 (permalink)
derek244's Avatar
Here's the deal. It appears to me that bolting on an aftermarket sway bar on an 8th gen Si is complicated. Fitment issues pop up whenever I search, along with end link and bracket concerns. I bolted a Neuspeed bar on my 97 GSR easily and it came with the all the parts needed. The only mod I had to make was trimming the ABS wire brackets. The addition of this bar was an immediate and awesome improvement. Am I missing something here? I want a complete bolt-on kit. I am not looking for a huge diameter bar though. Hmmm.
BTW, I will be installing the HFP suspension kit this spring too.
derek244 is offline
Old 02-27-2010, 08:00 PM   #2 (permalink)
Xtreme Thunder's Avatar
Joey
Fitment issues of such when you search?
Most popular options:
1. Progress 22mm
2. Eibach 19mm Adjustable. (~35% or ~65% stiffer than stock on the two settings)
Upgrading the endlinks are not totally necessary for DD, but the stock ones are tiny compared to Hotchkis, they would only help with rigidy. A must if you were to track the vehicle. I am using stock endlinks ATM.
Progress RSB comes with the reinforcement bracket and Eibach RSB does not. Some use the brackets, some do not. If you opt not to install a set, keep an eye on where the RSB connects to the LCA. I am sure you came across that thread where a few were ripping out the endlink from the LCA bracket. For DD, keep an eye out for potential issues, but if you go Progress, install the bracket they supply anyway. A must if you were to track the vehicle. I have Progress RSB, with Corsport reinforcement brackets (before they were supplied with the kit from the factory)
Install is simple, if you install it correctly. People that have rubbing issues have installed the RSB up-side-down. Have a can of PB Blaster, and a wire brush to clean the threads as you are backing out the nuts on the endlinks as they are stubborn if rusted a little. The 4 bushing bolts are simple, area could be tight if you don't have the correct tools. Tightening the RSB with the suspension loaded is the better way, you may need ramps if you don't have them. Same with that, some have tightened with load and some tightened with no load. I tightened with load. Make sure you grease the brackets with white lithium grease or equivalent. Mine need regreasing every 6 months or so, as it will tell me in the form of a squeak over every bump; regrease and it will go away until needed again. Any other noises are from improperly tourqing the hardware.
RSB will compliment the HFP Suspension nicely.
Xtreme Thunder is offline   Reply With Quote
Old 02-28-2010, 12:18 AM   #3 (permalink)
derek244's Avatar
1. Progress 22mm
I thank you very much for this reply. Due to the misinformation floating around, I was getting very confused. Looks like the Progressive is the way to go. I will be tracking at a few Solo events this summer which is why I want the sway bar. Of course, if I were a better driver I could do it without upgrades, but I am not.
derek244 is offline   Reply With Quote
Old 02-28-2010, 03:11 PM   #4 (permalink)
bluegreen86's Avatar
I'm Ron Burgundy?!?!
Thanks for the great info. Sub'd for spring when I can purchase and install the progress rsb!
bluegreen86 is offline   Reply With Quote
Old 02-28-2010, 03:30 PM   #5 (permalink)
Poweraide's Avatar
I have the Progress and have never had the popping sound. Just make sure the rubber bushings are greased up and everything is tight.
Poweraide is offline   Reply With Quote
Old 02-28-2010, 03:48 PM   #6 (permalink)
Vantage's Avatar
Luke
Does the kit come with Lithium grease? Progress kit that is.
Vantage is offline   Reply With Quote
Old 02-28-2010, 03:59 PM   #7 (permalink)
2xSi's Avatar
It comes with a white grease....probably lithium.
2xSi is offline   Reply With Quote
Old 01-04-2011, 01:25 AM   #8 (permalink)
Greg
the kit has everything, and i love mine on my r18 soooo nice thing handles completely different in a MUCH better way, doesnt feel like its gonna flip over in turns
tigerboy0213 is offline   Reply With Quote
Progress RSB richrios Suspension and Brakes 3 12-19-2009 03:20 PM
Stupid RSB s&mcivic2006 Ontario 8 11-30-2009 12:43 PM
Where to get RSB in GTA? taqwaa2009 Ontario 1 10-01-2009 04:00 AM
Help with Progress RSB FA5Tenough California North 2 08-01-2009 04:37 AM
How many using the Si rsb... RaGu07ex Mechanical Problems & Technical Chat 6 10-31-2007 09:13 AM
