Stock Camber Specs? - 8th Generation Honda Civic Forum
Old 02-27-2010, 06:02 AM   #1 (permalink)
fg2churppin's Avatar
Stock Camber Specs?
hey guys i just got some ingalls front camber that i need to put on my car plus an alignment due to the new coils.
would any one know the stock camber specs to a si?
just in case if the guys at discount tire dont know..i can tell them
thanks 8th!!
fg2churppin is offline
Old 02-27-2010, 04:22 PM   #2 (permalink)
VanSi07's Avatar
Umm... the whole point of bolts is so you can run camber OTHER than stock. You'd be defeating the purpose.
VanSi07 is offline   Reply With Quote
Old 02-27-2010, 04:34 PM   #3 (permalink)
VanSi07's Avatar
These are the recommended specs for having a little fun on the street:
Camber Front = -1.5 to -1.75
Camber Rear = -1 to -1.25
Toe front = 1/32nd toe out (I am now suggesting 0 toe, most people won't be able to realize that the car has the toe, especially on the street)
Toe Rear = 0
Old 02-27-2010, 05:14 PM   #4 (permalink)
Jonathan & Denise
How much camber can u run with the stock camber arms?? Front & rear
NiNiSzVtEc is offline   Reply With Quote
Old 02-27-2010, 06:22 PM   #5 (permalink)
VanSi07's Avatar
*sigh*
Camber can't be adjusted with factory components.
The amount you have depends purely on how lowered your car is. The rear gains a lot, the front gains very little.
Old 02-27-2010, 06:23 PM   #6 (permalink)
Firestrife's Avatar
Keens
Stock front doesn't really gain at all the MacPherson strut setup doesn't really gain any camber, from height adjustment or compression.
The rear is different and does gain camber from compression. If you lower the car the only real problem to worry about camber wise is the rears.
Firestrife is offline   Reply With Quote
Old 02-27-2010, 10:55 PM   #7 (permalink)
JDMlunatiK's Avatar
William
lol at this thread. hahahahahahahaha.
JDMlunatiK is offline   Reply With Quote
Old 02-27-2010, 11:03 PM   #8 (permalink)
brave21wr's Avatar
Mr.Brave
Originally Posted by VanSi07 View Post
*sigh*
QFT
just got my coils put in yesterday. shop told me cant really adjust any camber with stock stuff....they told me that i might wanna look into some rear camber arms to fix the slight extra camber cuz i m dropped one inch all around on my megans
brave21wr is offline   Reply With Quote
Old 02-28-2010, 01:16 AM   #9 (permalink)
i want stock specs so my tires down wear out faster thats the goal im trying to achieve and i did this afternoon, discount tires did a excellent job and im very pleased with the result, my car handles on rails now.
i know most people run different camber because they want that aggressive look, i dont.
id like to have my tires last unlike most ppl that just care about looks.
thanks for the help guys
fg2churppin is offline   Reply With Quote
Old 02-28-2010, 02:19 AM   #10 (permalink)
FALer's Avatar
Haywood Jablomi
Negative camber, especially in front, is about performance - getting more tire contact patch in the turns. I assure you one degree negative will help the handling without killing the tires.
Old 02-28-2010, 04:23 AM   #11 (permalink)
Firestrife's Avatar
Keens
If you want ultimate even tire wear daily driving no hard turns or anything 0 camber all around is that. If you want a little handling -1.5 won't hurt in the front and rear -1 would be ok.
Old 02-28-2010, 04:39 AM   #12 (permalink)
thanks guys i may do -1 or -1.5 in the front. yet to buy rear camber
do i need to get a alignment every time i play with camber?
Old 02-28-2010, 05:57 AM   #13 (permalink)
FALer's Avatar
Haywood Jablomi
Yes.
If your factory rear camber is at around -1 (or less), then nothing to worry about, so long as it is pretty even between sides. Some had too much rear camber from the factory, including mine (-2.1 degrees per side), which caused the rear tires to wear and hurt handling. No need to spend money if it is pretty good to begin with. It is the front that needs help, usually.
Old 02-28-2010, 06:05 AM   #14 (permalink)
Yes.
gotcha, thanks for the advice
Old 02-28-2010, 08:41 AM   #15 (permalink)
jasyatz's Avatar
Just to simplify..Have the shop get as MUCH negative camber as they can out of the front. -1.0 to -1.5 is fine for street driving.
Get a camber correction kit for the rear and have them get AS CLOSE TO -1.0 as possible. More than -2.0 will kill tires and really upset the balance of the car..
jasyatz is offline   Reply With Quote
Old 02-28-2011, 08:34 PM   #16 (permalink)
i did my alignment today and -1.2 both front and -0.7 both back with zero toe. with spc camber bolt and arm. guy told me have fun in the canyon lol
smokerz212 is offline   Reply With Quote
Need specs for stock brakes tda1337 Suspension and Brakes 10 01-22-2010 04:47 PM
OEM Camber Specs Civic Burgh 42 Suspension and Brakes 11 08-28-2009 06:33 PM
Stock Wheel Tourque Specs 2K8CivicSI Ontario 18 06-20-2009 08:10 PM
stock audio specs tonycivic08 I.C.E., Electrical, Security, & Navigation 7 07-03-2008 10:52 PM
Specs on CTR (FD2) Stock Suspension Si Speed 317 Suspension and Brakes 9 12-14-2007 11:06 PM
