Wonder what else I can do to suspension to make it handle better
Have a little extra money in the pocket. I have Pro S coilover, lowest setting. progress rear sway bar(just installed last night). I was reading about rear tie bar but most likely its just for show and chasis stifness even though our chasis are very stiff already. What else I can do to it to make it even less bodyroll and understeer?
No money for tires right now. My michelin tires for stock type s are still in good shape.
I heard braces and bars have no significant difference in performance.(except sway bars which i already have) |
![]() Join Date: Feb 2009
Luke
Sadly, better coils.
Skunk2 Pro S are more about drop than performance. Skunk2 Pro C's or BC N+ are the standard performance coilover around here. Also, tires are your BIGGEST way to improve handling. Stock type-s tires will be very limiting on how great your handling will be. |
Jason
RCA's if they make them for the Civic Si.
Other than that, better tires, and a professional alignment at a shop that knows about REAL handling (IE, they have a shop track car or something similar) will be your best performance enhancers. |
#16 (permalink) |
![]() Join Date: Apr 2008
Nick
Yeah the tough part is finding a place to do a correct alignment. Once the spring hits im going to get either a nice set of brigestone,yokohoma, or dunlop starspecs and find someplace to can really dial in my suspension. Other than that like everyone else has mentioned a nice set of coils( i have koni yellow and eibach) and bracing if you want a stiffer chassis which i will be installing. Neuspeed x brace,carbing strut tower bar,beaks lower tie bar. These will help the suspension do its job better and control chassis flex.
#17 (permalink) |
Luke
They are aparantly the best tires in the catagory by a longshot. I did extensive searching before I bought them and I havent found a tire that comes near it for $150 or less.
And no it isnt an all season. I would NEVER run all season tires. They are dreadful in the snow, which is the only reason you get an allseason over a summer tire. I have ALWAYS ran dedicated winter tires. This year: Ventus V12 224/15/17: Summer Michelin Xice Xi2's 215/45/17: Winter. |
#18 (permalink) |
![]() Join Date: Oct 2008
Rich
to the OP - you say youre at the lowest possible setting ....... but what camber are you running ? you also dont mention camber adjusters i.e. Ingalls bolts , S2 / SBC rear adjusters etc etc . do you have these ? - / + camber adjustments will make a huge difference in how your car handles ( understeer / oversteer )
the car is likely too low and youre below optimal ride height for correctly functioning suspension geometry - lift it a bit youll be surprised how much better it handles or go the control arm route if you are adamant about not raising the car - you say " less " bodyroll .... that doesnt necessarily equate to a faster lap time if thats your goal - if you simply want a flat handling car and arent worried if it actually is a bit slower around corners because of it then /shrug - I scrapped my Si front sway bar for an LX unit ...... it " rolls " more but its actually faster around a course ( other 8th members have had similar results its not just me ) Tires - for the price the dunlop star specs cant be beat ( although ill admit i havent driven the ventus ) - theres a couple of better sets out there but theyre more dough - ( Tirerack is way cheap ) ^^ As far as bracing helping the suspension do its job better ...... meh ... I guess yeah - I have bracing and I noticed the car felt much stiffer and less " variable " but it didnt equate to faster lap times . It did however raise my confidence level in the car which made it more enjoyable to drive so the net result was worth it - As far as upgrading the coils ...... yeah youd notice a difference but you gotta ask yourself if its really worth it . what are you wanting to do with the car ? Last edited by OttoX; 02-27-2010 at 12:35 PM. |
#19 (permalink) | |
Jason
| Comparison: Stock Suspension vs. HFP Suspension vs. KONI/ Swift Springs Suspension | Xtreme Thunder | Suspension and Brakes | 273 | 01-30-2012 12:12 AM |
| what can the k-series handle??? | sickyute | Forced Induction And Nitrous | 140 | 02-05-2009 02:24 AM |
| EX with stock SI suspension = Handle like a SI? | KraziAzn | Suspension and Brakes | 15 | 09-17-2008 12:06 PM |
| Do you really want to handle better? | Highrev1 | Suspension and Brakes | 73 | 05-18-2007 09:12 PM |
