![]() Join Date: Feb 2009
KiDD
no, pro-s is like a semi adjustable coilovers, it will rear will only drop so low, for Pro-c, it's fully adjustable, therefore the pro-s cost less than pro-c. i would go for pro-c if i were you
The ability to drop the car is comparable between the two. I believe both use the same rear perch.
They also have the same springs rates, which are considerably stiffer than stock. The major difference is the twin-tube construction on the S (poor damping and non-adjustable) vs. the monotube construction (better controlled, adjustable, and more resistance to fade). Also, only the Cs have shock travel adjustment. |
david
pro-s: height adjustable only
pro-c: height, preload, dampening, camber adjusment i personally have buddy club n+, and i love em...i cant say anything about pro-c but pro-s is too bouncy and stiff do to the lack of preload adjusment and shock travel |
| Skunk 2 pro s Lifespan? | silentkillz1 | Suspension and Brakes | 9 | 10-12-2008 03:44 PM |
| skunk 2 pro s | mosi123 | Suspension and Brakes | 2 | 03-10-2008 01:54 AM |
