what should i do next? - 8th Generation Honda Civic Forum
Old 02-25-2010, 02:24 PM   #1 (permalink)
davecivic91's Avatar
hey all. so far, my suspension mods on my 08 si are HFP suspension, progress rear sway bar, and a meghan H brace... what should i do next for better handling without having to go to a coilover setup?
davecivic91 is offline
Old 02-25-2010, 02:26 PM   #2 (permalink)
FijiBlueFG2HT's Avatar
Mitch [Ryan #3]
On our cars braces and supports are rather pointless. The chassis is quite stiff already.
1. Get performance tires
2. Adjust camber for maxmimum performance.
FijiBlueFG2HT is offline   Reply With Quote
Old 02-25-2010, 02:31 PM   #3 (permalink)
galaxygrey13's Avatar
Antonino B. B. Leyva
You can get
Camber arms,
camber bolts,
aerodynamic bodykit to improve downforce,
Adjustable GT wing,
Big brake kit,
lighter wheels, alot of people go with RPF1's
alot better tires which is one of the most important ones.
galaxygrey13 is offline   Reply With Quote
Old 02-26-2010, 12:33 PM   #4 (permalink)
Originally Posted by galaxygrey13 View Post
You can get
Camber arms,
camber bolts,
Adjustable GT wing,
Big brake kit,
i believe i have camber bolts? the addition of camber arms will help? yeah... i bought konig feathers (17 lbs?), and i just got dunlop z1 star spec tires...
davecivic91 is offline   Reply With Quote
Old 02-26-2010, 01:12 PM   #5 (permalink)
humboldt1498's Avatar
Forrest
Camber bolts and arms both allow for a wider range of camber adjustment. You don't need both unless you are trying to run insane amounts of camber, which isn't going to make your car handle better. Honestly, I see little you can do that will make a big difference at this point.
humboldt1498 is offline   Reply With Quote
Old 02-26-2010, 01:14 PM   #6 (permalink)
CivicSiFA5's Avatar
Nathan
....you do need both, camber arms for the rear and bolts for the front
CivicSiFA5 is offline   Reply With Quote
Old 02-26-2010, 01:25 PM   #7 (permalink)
Forrest
I frogot that they don't make bolts for the rear. You just need to make sure you have the ability to adjust the camber at both the front and rear. You can buy arms, or Ingalls makes an adjustment bracket for a little cheaper.
Old 02-26-2010, 01:32 PM   #8 (permalink)
cbizz's Avatar
Chuck Mitchell
new tires hands down
cbizz is offline   Reply With Quote
Old 02-26-2010, 04:54 PM   #9 (permalink)
say i got buddy clib n spec coilovers... am i going to see a complete night and day difference over HFP or no?
Old 02-26-2010, 05:04 PM   #10 (permalink)
cambodianricer's Avatar
JLee
tires tires tires
cambodianricer is offline   Reply With Quote
Old 02-26-2010, 05:06 PM   #11 (permalink)
drk
Nope. I would say you would notice a decrease in performance. That is until you get the car aligned... Then you might notice a difference. I would stick with the HFP's...
drk is offline   Reply With Quote
Old 02-26-2010, 05:28 PM   #12 (permalink)
Forrest
Old 02-26-2010, 05:32 PM   #13 (permalink)
CivicSiFA5's Avatar
Nathan
lol decreased performance w/ coilovers? outside of custom spec matched springs and struts you can't top coilovers. As long as you have them dialed into your preference it'll be a nice upgrade.
Old 02-26-2010, 06:25 PM   #14 (permalink)
Forrest
Are you trying to say any coilover for the civic will handle better then the HFP suspension? Because that is defiently not true.
Old 02-26-2010, 06:38 PM   #15 (permalink)
CivicSiFA5's Avatar
Nathan
buddy club n+ isn't some cheap ebay knock off
Old 02-27-2010, 01:35 AM   #16 (permalink)
will there difference from going from s drives to z1 star specs be greater than the handfling difference if i were to go from HFP to buddy clubs n plus?
