Negative camber and hard braking. - 8th Generation Honda Civic Forum
Old 02-23-2010, 04:35 PM   #1 (permalink)
xheartcore_boyx's Avatar
3bood aka Addy aka Bo dawood
Exclamation Negative camber and hard braking.
I have -2 camber up front and -1.5 on the rear wheel and have heard about a relationship between braking and having negative camber up front.
I have had an accident recently and had to hard braking, i was going straight, yet the car still swerved to the side while braking, making it hard to have control again, i almost hit a speeding 8 wheeler that was going on the near-by lane....very dangerous.
First thing came to mind was my 8inch wheels on 225 tires...but after farther searching, i suspect it could be the negative camber..
Anyone got any info on this?
xheartcore_boyx is offline
Old 02-23-2010, 04:36 PM   #2 (permalink)
:banned:
Toe can contribute to instability as well as brake biase being off(too much on the rear tires if I'm not mistaken)I'd post this question in the brakes section,specifically the thread created by "Moose"
bossman is offline   Reply With Quote
Old 02-23-2010, 05:09 PM   #3 (permalink)
VanSi07's Avatar
Camber affects steering because a tire generates a force towards the side that the top is leaning towards.
This combined with the ABS brake pulsing could lead to interesting things during hard braking.
But, then again, I run similar camber and my braking is just peachy, so there may be another factor at play.
VanSi07 is offline   Reply With Quote
Old 02-23-2010, 06:01 PM   #4 (permalink)
mohouse's Avatar
Mo
addy, ya i would blame the toe reading more than the actual neg camber in the front/rear.
http://i101.photobucket.com/albums/m51/jrmartinez24/Ricky/c1312c1a-1-1.jpg
mohouse is offline   Reply With Quote
vibrations when braking hard loccie Mechanical Problems & Technical Chat 20 10-15-2009 09:17 PM
Too much negative camber? Front camber kit review aki Suspension and Brakes 11 06-20-2008 03:26 AM
grinding noise under hard braking? devilman2075 Mechanical Problems & Technical Chat 9 03-10-2008 02:19 AM
smell from braking hard with Abs MoragaLX Mechanical Problems & Technical Chat 4 02-07-2008 06:54 PM
Horrible grinding feeling when braking hard Guu123 Mechanical Problems & Technical Chat 5 11-01-2007 06:14 PM
