Old 11-03-2006, 06:37 PM   #1 (permalink)
rizwanmakani's Avatar
Just a quick question
I found 17MM REAR SWAY-BAR KIT W/BUSHINGS for 80$ and the guy said it will work with both coupe and sedan... The rear sway bar that orignally comes with the sedan is it 10mm and also will 17mm make difference or do i need 22mm??? any suggestion will be helpful... Thank You
rizwanmakani is offline   Reply With Quote
Old 11-03-2006, 06:39 PM   #2 (permalink)
CivicWithNav's Avatar
it'll make a big difference
I had SI sway bar on my EX and wow it tightened up the rear end
17mm sway bar i believe is stock bar setup.
you can buy brand new SI bar/bushings/bracket at honda for like $70 with tax
22mm is the progress sway bar and they are $150ish shipped from ebay
Old 11-03-2006, 06:43 PM   #3 (permalink)
So you prefer Si sway bar... but will it work with my lx sedan???
and it is $70 with tax... do they install it too or i will have to do it on my own?
Thank You
Old 11-04-2006, 02:29 AM   #4 (permalink)
si_civic's Avatar
A/Cst.D.F.Abate
^ I personally think it would work according to a few posts I've read recently. Don't quote me on it, however.
Old 11-04-2006, 02:46 AM   #5 (permalink)
dtexan's Avatar
It will fit fine I have one on my LX sedan. It only takes about 40min to install and can be done in your drive way with basic tools.
dtexan is offline   Reply With Quote
Old 11-04-2006, 03:24 AM   #6 (permalink)
el_ben2's Avatar
well i use to have the Si sway bar in my setup and the cars handling has inproved a lot
then i swap to the progress rear sway bar and the car suffer a lil of understeer (note: i dont change the front sway bar)
but when i put the cusco front strut bar the car take corners like a go-kart
ill def. recomend you the Si sway bar... and if you can... buy the front too
that will make a lot of difference
el_ben2 is offline   Reply With Quote
Old 11-05-2006, 02:16 PM   #7 (permalink)
Thank You sooooo much guyz for the help
Quick Warranty-type question shawn-o Garage 7 11-10-2007 01:00 PM
A quick question. please answer SilverEX Civic Coupe And Sedan 0 10-04-2006 09:49 PM
Quick Question... Ortiz83 Civic SI 5 06-15-2006 12:12 AM
Quick Question.... its dumb.. BlackSIguy Garage 5 12-22-2005 11:32 PM
